It is currently Thu Jun 18, 2026 4:04 am
PostPosted: Wed Aug 12, 2015 5:29 am
We just recently did a valve adjustment, but that wouldn't have anything to do with that would it?
Pull the valve cover, and have a look-see.
PostPosted: Wed Aug 12, 2015 8:42 am
Car Model: 1967 Dodge Dart GT 225 Slant Six
Fuel, air, spark.... Bought my own set of feeler gauges today as I will always need them and planning to borrow a compression gauge. Warm motor, all plugs out, and throttle open is what I've read to do when testing for compression. I'll give an update once I've tested both.
Current Project: 1967 Dodge Dart GT, 2dr Hardtop California Car with 225 Super Six, Automatic 904 Transmission, and Factory A/C
PostPosted: Wed Aug 12, 2015 9:00 am
While you're at it pick up a remote starter switch that can be operated while under hood; it connects to starter relay. When I perform compression tests I connect battery charger to battery.
PostPosted: Wed Aug 12, 2015 8:42 pm
And remember to remove air filter and have the carb butterfly wide open while testing compression. (Or remove carb).
/6 Dodge Charger 69
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 5 guests
