It is currently Mon May 04, 2026 5:41 pm
PostPosted: Fri Sep 04, 2015 11:45 am
I have a slight knock back and forth in my steering that is coming from the "Coupler".
Is it best to Replace the whole part or rebuild it?
1964 Dodge Dart GT manual steering.
1964 Dart GT
 Post subject: knock?
PostPosted: Fri Sep 04, 2015 3:29 pm
Do you mean an irregularity in motion when turning it, like it's sticking or klunking at some point?
Usually these are not replaced, but rather rebuilt using a kit. Like this:
http://www.ebay.com/itm/Mopar-A-B-E-C-B ... 85&vxp=mtr
The pin (top left in the pic) that holds the shoes sometimes break, or the shoes (funny shaped pieces middle left) wear or break or the spring that holds the shoes (bottom left) breaks. Usually the pot itself is OK.
But, if your pot is cracked or the splines are stripped or something, then yes, replacement is warranted.
http://www.ebay.com/itm/MOPAR-Steering- ... c1&vxp=mtr
Are you sure its the pot coupler and not the steering box?
Brian
https://tinyurl.com/yynpj4v2
 Post subject: one more thing...
PostPosted: Fri Sep 04, 2015 3:33 pm
Those darn lids on the pot couplers have little tabs that bend over the edge of the pot and into little recesses. This is supposed to hold the lid on and keep the grease protected, sealed in. I have never been able to get that part right, I've clamped the lid down, bent the tabs, then released, etc., but the lid always seems to come loose.
I recommend this item which totally fixes that problem.
http://www.ebay.com/itm/Rare-Mopar-2996 ... 89&vxp=mtr
Totally worth it for me.
Brian
PostPosted: Fri Sep 04, 2015 5:03 pm
My preference is heavily against those band-aid clip things, and heavily in favour of the (much!) improved slide-on cover available from Steer & Gear, separately or as a part of their rebuild kits. Their website's foozled at the moment, but 800-253-4327.
 Post subject: Re: one more thing...
PostPosted: Sat Sep 05, 2015 8:38 am
Brian
A friend of mine in MI found the same TSB and found one on at a dealer in HI and also found there was a shorter version which he acquired. He had 500 of each made and was selling them on-line and at various Mopar swap meets with and without a rebuild kit. He sold out to another vendor several years ago as he couldn't find another company local to him to make more of the clamps. Kind of hokey but hey, it's what Chrysler came up with to solve a problem.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Sep 06, 2015 5:59 pm
YES.
I will call Steer & Gear on Tuesday!
Thanks everyone!
1964 Dart GT
 Post subject: Dan is the man...
PostPosted: Mon Sep 07, 2015 9:36 am
I figured Dan had a better source/material for this. I'd never heard of Steer & Gear. That wire clamp is heavy/thick, and there's no way it's gonna leak. That said, the cap from Steer & Gear seems like a much more elegant solution; glad to see somebody is making some upgrades for the old mopars.
brian
 Post subject: Question for Dan
PostPosted: Mon Sep 07, 2015 9:39 am
Hey, Dan, if you had your choice of steering gear vendors, which makes the best rebuilt gearbox, is that RedHead, Steer & Gear, Firm Feel or another vendor?
thanks,
brian
