It is currently Tue Oct 13, 2026 2:29 pm
 Post subject: Radiator for 65
PostPosted: Fri Sep 11, 2015 10:59 am
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
Sorry I didn’t make it to Bristol. I’ve been traveling a lot lately.
I finally need to replace the radiator in my sedan. It’s still the brass Slant6 original narrow one. Re-cored probably 20 years ago. I can’t get the car to run cool at highway speed. Seems fine putting around town. Anyway, I’ve looked at a bunch of options online and I wondered if you guys had a suggestion. Don’t care about originality. That went away long ago.
I’ve seen some guys use these and have a radiator shop move the outlet to the other side
http://www.championradiators.com/Dodge- ... -1965-1966
I found these but they’re VERY pricey.
http://www.usradiator.com/plymouth-vali ... iator.html
Any ideas?
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Fri Sep 11, 2015 11:25 am
See this post on the Champion Rad.
http://www.slantsix.org/forum/viewtopic ... t=radiator
I also used the universal radiators from Summit in both my car and truck with good results. You have to do some more fabrication of the brackets for yourself though. See my 65 Valiant thread in the Virtual dragstrip for details
http://www.slantsix.org/forum/viewtopic ... tor#382830
PostPosted: Fri Sep 11, 2015 9:42 pm
I use Griffin or Afco universal Chevy style radiators and build my own mounts and use universal hoses from the parts store. Cheap (~$200) and work well. Hope to see you at a race sometime.
PostPosted: Sat Sep 12, 2015 5:46 am
Hi Mike!
My 65 has a copper/brass one listed for a slant Volare (Murray 433525), along with a Volare upper hose.
$168+tax and it was in stock here in town.
O==\=/==O
"A mechanic is Somebody."
- Jim Preston
PostPosted: Mon Sep 14, 2015 2:23 am
CALL CHAMPION. I believe when you order, you can specify which side to put the outlet ports.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 7 guests
