It is currently Tue Oct 13, 2026 9:38 pm
PostPosted: Tue Aug 11, 2015 3:27 am
I want to use some sound deadener in my 62 Valiant.
What is a good product to use on doors and how do you do it?
Do I need to clean the door insides first?
I am thinking of using a lead impregnated material for the floor and trunk (I believe this product was specially designed for sound deadening in trucks). I am interested in anyone with experience using this product and the soundeadening results.
Thanks
PostPosted: Tue Aug 11, 2015 5:51 am
On my previosly owned 70 Dart I pulled all the sound deadening out of a 79 LeBaron parts car I had and put it in the Dart. It worked well. I would think you could find a car in the junk yard that was premium enough to have good material. Comercial products for this are very, very expensive. A cheap alternative is worth looking for.
I got rid of some of the boom from the back of this car by putting a 2x4 behind the seat fastened vertically between the package shelf and the two diagonal braces.
For the doors I am considering using self stick floor tile. Keep in mind this may promote rust, and will make your car heavier. Maybe coat the inner door skin with heavt brushable undercoat. I am interested in what others have to offer.
Sam
Sam
PostPosted: Tue Aug 11, 2015 7:46 am
Dynamat.
PostPosted: Tue Aug 11, 2015 9:07 am
http://customcoatingswest.com/shop/heat-noise-reducer/
http://www.lobucrod.com
PostPosted: Tue Aug 11, 2015 10:02 am
I used Summit's knockoff of Dynamat and am very happy with the product.
B
These ones go to eleven...
PostPosted: Tue Aug 11, 2015 1:43 pm
Both of those look great, and reasonably priced. Thanks Reed.
Sam
PostPosted: Tue Aug 11, 2015 2:25 pm
I have ben on the hunt for reasonably priced heat and sound deadening materials for my van for a few years now. Those two are the best options I have found. There is a place local to me that sells the HNR for $45 per gallon. Can't beat that with a stick!
PostPosted: Tue Aug 11, 2015 4:54 pm
The Summit copy of Dynamat is really good. Before that, I replaced all my window rubber. Cut the noise in half just by doing the window rubber alone.
PostPosted: Wed Aug 12, 2015 5:40 am
Some newer cars have something sprayed onto inner side of door skin that looks like good old undercoating. Coating just a rectangular strip equivalent to about 1/3 skin's area centered would kill most of the tin-can tink when closing door.
Killing wind noise requires new gaskets, and window seals & track material. Sealing door with 6 mill plastic sheeting secured with 3M Strip Calk 08578 strips before attaching door trim panels will keep water & air from infiltrating cabin.
PostPosted: Mon Sep 21, 2015 8:20 am
I used the Home Depot foil type insulation. It's cheaper and probably doesn't work as good as the legit automotive dynamat type products but it wasn't real loud inside the car to begin with anyway.
PostPosted: Mon Sep 21, 2015 8:49 am
Dynamat.
Ditto. I just did my friends 330 floor with it and it was really easy to cut and shape to the contours of the floor. The adhesive back was also a bonus. They sell a thinner sound deadener for door panels etc. The Summit brand knock-off is probably as good but I've never used it.
PostPosted: Sat Oct 31, 2015 9:19 am
I agree with the other members who said Dynamat. It works great and really quiets the ride.
I was watching Jay Lenos garage recently and he showed it being put into one of his restorations and he talked about how great it was too.
PostPosted: Sat Oct 31, 2015 9:50 am
I can cut out all the noise by removing my hearing aids. Quieter than a Lexus after that. :lol:
PostPosted: Sat Oct 31, 2015 12:27 pm
What about Arizona-style roof coating??? (In door panels.)
Users browsing this forum: No registered users and 30 guests
