It is currently Sun Jun 14, 2026 3:10 am
PostPosted: Fri Nov 06, 2015 5:54 pm
Does anyone know what the valve angle (off vertical) is for the /6? For example, 340 is 18* and SBC is 23*...
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Fri Nov 06, 2015 6:07 pm
30 degrees + - some unknown amount in the head.........
:roll:
PostPosted: Sat Nov 07, 2015 4:05 am
He means off the axis of the cylinder. I think I heard it is the same as LA engines (18 deg), but I don't really know. I am interested too!
PostPosted: Sat Nov 07, 2015 6:55 am
I measured about 13 +/- a degree or so on the drawing in the Mopar Engines manual.
PostPosted: Sat Nov 07, 2015 7:43 am
I measured the angle on a head a while back but ended up not doing whatever it was I wanted the angle for.
The number that sticks in my mind is 11 degrees.
--> The Diesel Corvette <--
PostPosted: Sat Nov 07, 2015 8:57 am
OK, I got curious so went out to the shop where I happen to have a bare head getting ready take to the machine shop.
With an old intake valve and my 'anglelometer' I measured 11.5 degrees.
PostPosted: Sat Nov 07, 2015 1:05 pm
Good to know, guys. I thought about measuring one on the bench, but y'all beat me to it.
11.5 deg might explain why you can make a good flowing head (relative to the cyl displacement), even with the 30 deg angle between the intake surface and the cyl axis. Need to think further about this...
Cheers,
PostPosted: Sat Nov 07, 2015 2:00 pm
Just dedicate 30 billion neurons to 3D mapping....you will figure it out.
PostPosted: Sat Nov 07, 2015 3:03 pm
Thanks everybody!
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Sun Nov 08, 2015 9:12 am
The factory blueprints spec the valve guide angle at 12 degrees.
Early SL6 engine development engineering documents say that 14 degrees was also tried & tested but 12 degrees worked "better" for the engine's intended use.
PostPosted: Sun Nov 08, 2015 9:27 am
I was hoping you would chime in, Doug - thanks! 12 deg it is...
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 6 guests
