It is currently Fri Nov 27, 2026 2:22 pm
PostPosted: Mon Nov 23, 2015 12:37 pm
Finally rebuilding the front end of my Dart and I have noticed a few discrepancy's? :shock:
First) The Lower Control Arm Pins are different on the 1975 than on the 1964? Old uses a cotter pin and new(er) does not? (see pics)
NEW
OLD
Should I just drill a hole and use the castle nut & cotter pin?
Second) How in the world are you supposed to tighten the New lower control arm bumper? (I cut the old one off) Deep socket will not fit!
Any suggestions appreciated!
1964 Dart GT
PostPosted: Mon Nov 23, 2015 12:41 pm
1. A self-locking nut replaced the cotter-pin.
2. Never had that issue, sorry.
PostPosted: Mon Nov 23, 2015 2:20 pm
Self Locking nut? so does it need to be replaced after use? The nut that came off the parts car does not seem like anything special. :?
1964 Dart GT
PostPosted: Mon Nov 23, 2015 2:45 pm
Isn't the nut beveled on one side? Or does it have little dots on the flanks?
PostPosted: Mon Nov 23, 2015 2:53 pm
Yes, it does have a slight bevel to one side, but no dots. Is locktite ok to use here?
1964 Dart GT
PostPosted: Mon Nov 23, 2015 3:30 pm
Car Model: '23 T-bucket
Danarchy; are you familiar with what's called "Nylock" nuts? One side has an extra area for a nylon washer, that when screwed onto your bolt/stud, gets threaded by the same threading engagement. It has the effect of a locking device. In your pic of the new pin, it appears that the nut is a nylok-type nut.
If you go to get new locknuts, I implore you to NOT use pinch-lok type nuts. They are one-time use only, and damage your threads when you put them on and take them off.
Roger
PostPosted: Mon Nov 23, 2015 8:30 pm
Roger - I am familiar with Nylocks nuts, the one in the picture with the New control arm is not a Nylock. What should I be looking for? I was Very Surprised when I took the old one off and it had a castle nut, I would probably feel better if the new one was also. Is there any reason I shouldn't drill a hole and use a castle nut and cotter pin?
1964 Dart GT
PostPosted: Mon Nov 23, 2015 8:36 pm
How about a jam nut?
PostPosted: Tue Nov 24, 2015 12:39 pm
O.K., I went down to Fastenal and bought a couple of different nuts. One similar to the original on the New arm and the other a Nylock.
The Nylock is a bit larger,but will catch threads fully on the nylon.
Jam Nut? NOT use pinch-lok type nut? Different people call things by different names, can you post a picture?-Thanks
1964 Dart GT
PostPosted: Tue Nov 24, 2015 1:53 pm
Jam nut = second nut against primary nut; usually thinner, but doesn't have to be
PostPosted: Tue Nov 24, 2015 2:17 pm
:lol: Thanks Ed! Makes perfect sense now.
1964 Dart GT
