It is currently Mon Jun 15, 2026 4:19 am
 Post subject: Block oil mods?
PostPosted: Mon Nov 23, 2015 4:28 pm
Read the article about block mods for racing. There is a section describing drilling 1/2 inch holes between the lifter bores and installing 'stand-offs' to aid in lifter oiling. Where can someone get these stand-offs and how tall are they?
PostPosted: Mon Nov 23, 2015 5:06 pm
When my machine shop does this process he uses valve guides and they are about 1/2 high .... eyeball measurement.
I'm sure doc Will chime in.
 Post subject: Re: Block oil mods?
PostPosted: Tue Nov 24, 2015 6:24 am
Car Model: 64 Valiant
We used these in hundreds of circle track engines and we just used short brass pipe nipples.
PostPosted: Tue Nov 24, 2015 9:18 am
The main goal with this mod is to get more oil around each lifter so more oil drops down around the lifter & onto the cam / lifter surface, for better lubrication / cooling at the lifter to cam interface point.
Drilling the extra holes just helps crankcase ventilation.
You can use whatever... to make the stand-offs but these days, I don't use stand-offs much.
Instead, I have a large multi-flute 1 inch diameter countersink, with a long shank and I use that to put a large 45 degree countersunk "ring" around the top of each lifter bore.
The added recesses catch and directs more oil thru all the lifter bores.
Note: I always have to re-ream & hone out each lifter bore, after countersinking, to remove the burr the countersink creates. ( you want to hone the bores anyway, just to be sure they are smooth and have the proper oil clearance... just be sure do it
after the countersinking operation)
PostPosted: Tue Nov 24, 2015 11:55 am
OK. That pretty much answers my question. I honestly didn't see the need for the stand offs since the engine has a 30* tilt.
Thanks.
 Post subject: If...
PostPosted: Tue Nov 24, 2015 4:29 pm
If you need more oil directly to the face of the cam shaft lobe, you can use a tool like comp cam has, that will score a line when drawn up the lifter bore allowing a dribble of oil on the face...
PostPosted: Wed Nov 25, 2015 5:39 am
I hone the lifter bores quite a bit on the race engine.
No problems.
I have not done the countersink trick, but It's a good idea and will be doing it on future builds.
PostPosted: Wed Nov 25, 2015 2:34 pm
How much do you countersink it?
PostPosted: Thu Nov 26, 2015 7:31 am
I shoot for .060 with a 45 degree c-sink. (90 degree "included" angle)
The factory already did a rough countersink so some of the bores are easy to "touch-up" but others take a bigger cut and more work.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
