It is currently Mon Jun 01, 2026 3:58 pm
Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3
PostPosted: Tue Feb 02, 2016 12:02 pm
Major bummer. I bought a cheap beater that way - couldn't even rotate the engine with a breaker bar and the plugs out.
Good luck with the buildup...
PostPosted: Tue Feb 02, 2016 12:06 pm
Bummer!
PostPosted: Tue Feb 02, 2016 12:40 pm
82k mile slant with 904 trans attached, $500: http://cnj.craigslist.org/pts/5386285397.html
Sounds like a deal to me! Should be close to you. New Jersey is a small place.
PostPosted: Tue Feb 02, 2016 2:35 pm
I think a nice fella out in Harrisburg area has a donor one. Gotta go cheap. Nice of him to help us out. sitting a while, but ran when pulled.
Just need to find time for a road trip......
PostPosted: Wed Feb 03, 2016 10:52 am
Oh noooooooooo :cry: that would explain a lot
If you need an intermediary to go out to Harrisburg, let me know. I can help out if you need, pretty sure if I fold the seat down in the Cherokee I can get the engine in there with some help, and some help to get it back out.
PostPosted: Wed Feb 03, 2016 12:24 pm
I'll figure out how to get there - just not sure when.
Should give you some comfort to know you were doing things right! The mopar gods were just stacked against you!
PostPosted: Thu Feb 04, 2016 12:10 pm
that does help my mind a bit :)
truly though, if ever you need some help transporting parts (whether it's for my car or others) let me know - we're close enough, and i can't actually express how cool i think what you're doing with your students is!
PostPosted: Mon Feb 08, 2016 5:38 pm
Picked up the engine from Manheim PA area. Complete, from a 69 D100. 2 barrel, electronic ignition dizzy. complete. Should work. Just need to fix the larger register to flywheel issue.
Steph: PM me your address so I can mail you the PA tag back!
PostPosted: Tue Feb 16, 2016 7:01 pm
I don't have a web host for picts. but...check out the driver side door post repair: http://www.forabodiesonly.com/mopar/sho ... p?t=340038
Still would be nice to find a 67 Oil pan and PU. may just have the pull the one off the 67 170 engine.
PostPosted: Tue Feb 16, 2016 7:42 pm
Nice work!
