It is currently Sun Jun 21, 2026 8:09 am
PostPosted: Wed Feb 17, 2016 9:40 am
Car Model: 1964 Dodge Dart GT - 1964 Dodge Dart Wagon
http://www.hotrod.com/how-to/engine/mop ... ix-engine/
PostPosted: Wed Feb 17, 2016 10:14 am
Cool! Nice job Romeo! :D 8)
PostPosted: Wed Feb 17, 2016 10:32 am
300 horses with a carb and about 320 injected. Pretty dang good for a slant.
PostPosted: Wed Feb 17, 2016 10:42 am
I remember when that was new......10 years ago.
PostPosted: Wed Feb 17, 2016 12:30 pm
I remember reading about that too years ago..........
PostPosted: Wed Feb 17, 2016 12:33 pm
Huh. I missed that the first time around. Still is interesting to read, though.
PostPosted: Wed Feb 17, 2016 12:57 pm
Yep that is an old article but a great read! i go back and read those types of articles pretty often!
PostPosted: Thu Feb 18, 2016 3:24 am
Engine is still running in Brian Droschak's '67 Dart (formerly Romeo's car). High 12s or low 13s at the strip.
Slant on,
PostPosted: Thu Feb 18, 2016 7:36 am
I read that one before as well, but it's good enough to read again. I remember an old Hot Rod article back in high school about hopping up the old 4 cylinder Nova engine. All my buddies thought it was stupid, just throw in a V8. I was intrigued by making power from an inline back then, and I guess the intrigue never left. Those old friends still don't quite get it. I guess they never will. (Interesting side trivia, GM made those old Nova 4 cylinders from 1962 at least until 2013 and sold them as boat motors, kinda along the same story lines as the slant).
PostPosted: Thu Feb 18, 2016 9:40 am
That motor also became the Pontiac Iron Duke. :D
PostPosted: Thu Feb 18, 2016 9:48 am
The hot setup is take the crossflow Fiero head and adapt it to the larger (181-ish cubic inch) block. Has chevy smallblock crank flange and bellhousing.
Oh how I wish Mopar had made an OHC 4 cylinder version of the slant six with V8 bellhousing. Then the fabled aluminum headed OHC slant could be a reality.
PostPosted: Thu Feb 18, 2016 12:25 pm
Hyster used the 3.0 in lift trucks until about 2005 when they couldn't get them to pass EPA regs.
PostPosted: Mon Feb 29, 2016 4:30 pm
Slant on,
Yep and guess where the injection manifold, fuel rail, and injectors ended up?
https://youtu.be/O_ZMTRbFNOU
Yep on a beige injected f body.!
PostPosted: Mon Feb 29, 2016 5:11 pm
Cool! No better plae for it. But you need another belt on your AC compressor and that breather needs to get plumbed in somewhere.
PostPosted: Mon Feb 29, 2016 7:01 pm
I did take care of the breather.
that video is from 7 years ago, but I still use and drive it in this configuration.
The c-171 compressor does not work with a single pulley and a Clifford manifold.
To use it with the Clifford manifold I had to modify the mounting a bit then add a double groove v-8 pulley and run the single belt in the rear groove.
