It is currently Fri Nov 27, 2026 12:43 am
PostPosted: Fri Feb 26, 2016 7:58 pm
So I pulled my Dash out in December to put a new speedo in, and new bulbs. Then I got sick.......so this week after work I have been getting it all back together.
I realized that on the RH side looking at it from the back, there is not a plug under my dash for the 3 stud/pins on the small circuit board. My L blinker indicator that I thought was bad......dosent work, I popped the dash forward and REALISED that crap, I cant find where the plug is???? Then realized I didn't pull one off. So ????
I need to know if anyone has a 67-69 Barracuda, and what the plug or plugs look like that go on that side. What color are the wires? Any help would be great.
Andrew/Kidd
Wife's: 64 Valiant
 Post subject: Voltage Reducer
PostPosted: Sat Feb 27, 2016 8:28 am
Car Model: '64 Valiant Convertible
This little 3 pronged puppy lowers from 12 to 5 volts for your fuel and temp gauges.
 Post subject: Wiring Diagrams
PostPosted: Sat Feb 27, 2016 8:36 am
http://www.mymopar.com/downloads/1967/67BarracudaA.jpg
http://www.mymopar.com/downloads/1967/67BarracudaB.jpg
Of course the actual dash cluster isn't shown, but all the pins from the harness connections are.
Also, I may have misspoke about the voltage reducer. Can't remember which year they began using those... :shrug:
PostPosted: Sat Feb 27, 2016 2:06 pm
My Dart has broken pins on end of its circuit board. All I did was clean and solder jumper wires about 10 inches long on each of the small thin copper strips, crimped on Packard #56 (I think is the number) housed in a multi connector. Then removed the old round pin female brass connectors and their plastic housing from their respective conductors, and crimped on the mates to the new jumper harness/pigtail. (See new green, orange & yellow conductors)
You can find the parts and connectors here. if needed.
PostPosted: Sat Feb 27, 2016 2:16 pm
"They" have always used a voltage limiter, just some were housed within the fuel gage. I'm fairly sure limiter equipped fuel gage has three bolts holding gage to circuit board, where a non limiter equipped gage has two bolts, and that little three bladed turtle you nicely illustrated plugged into circuit board in plain sight along with a condenser to reduce "make and brake" noise from its contacts interfering with one's radio listening enjoyment.
My homemade pig tail fix has been trouble free for nine years.
Users browsing this forum: Amazon [Bot] and 3 guests
