It is currently Sun Jun 21, 2026 10:43 pm
PostPosted: Thu Mar 03, 2016 1:53 pm
How do you tell if you have the early head that needs the spark plug washer vs the 63+ head that doesn't use the crush washer.
Thanks
PostPosted: Thu Mar 03, 2016 4:17 pm
See if you can find a casting date on the head -- probably under the valve cover.
PostPosted: Thu Mar 03, 2016 5:17 pm
Looks like a 72-73 head with number 3614850-1.
I just thought maybe a noticeable difference outside the valve train. Didn't really want to pull the cover.
PostPosted: Fri Mar 04, 2016 12:35 am
Well, keen, a '72-'73 head is nicer than a '62 or '63 head.
AFAIK, there's no external (outside the valve cover) clue to discern a '62 from a '63 head.
PostPosted: Sat Mar 05, 2016 3:08 pm
What makes the 72 head better than the 60 head? Does it have better chamber shape or something?
PostPosted: Sat Mar 05, 2016 4:26 pm
Yep, better combustion chamber shape starting in '67 for more complete combustion.
