It is currently Tue Sep 29, 2026 10:00 am
PostPosted: Thu Mar 24, 2016 12:09 am
curious to see if it is possible to replace the slant six in my 66 Dodge Van, A 100, with a more modern, 6 cylinder or so?
Thank you for your opinion and assistance. :?
Dodge A100 Rookie
PostPosted: Thu Mar 24, 2016 1:00 am
Anything is possible.
What do you have in mind?
PostPosted: Thu Mar 24, 2016 3:05 am
A 6BT 12v would be cool.........
:wink:
PostPosted: Thu Mar 24, 2016 7:40 am
BMW engines slant that way. You had best be good with electrical systems and mechanical fabrication to use one of the EFI engines and most anything you'd want to use is EFI. Could do a Volvo turbo 4 cylinder, but there's not much place on an A van for an intercooler. If you want a more modern van of that size see about a Toyota. They already have EFI, disc brakes, etc.
PostPosted: Thu Mar 24, 2016 8:40 am
A 66 A series van, if equipped with an automatic transmission, would have the adapter plate necessary to mate the slant six to a smallblock transmission. Given that the transmission in the van (if automatic and original) has the smallblock bolt pattern on the bellhousing, a swap to a later model Mopar 3.9 truck v-6 would be fairly straightforward, even a TBI or Magnum MPFI version. The hardest part would be the electronics and fuel supply, but even those wouldn't be too difficult. Since the A series vans came with 273s and 318s, one could use the factory A series motor mounts and accessories on the 3.9.
Users browsing this forum: DuckDuckGo [Bot] and 10 guests
