It is currently Thu Jan 01, 2026 4:45 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Slant 6 bearings
PostPosted: Fri Apr 29, 2016 7:09 am
Thanks for that,but wa means Western Australia
PostPosted: Fri Apr 29, 2016 8:09 am
Ah, okay, then it's a bit harder for most of us in Oregon and Washington to lend a hand with a heavy part.
PostPosted: Fri Apr 29, 2016 9:27 am
Id give you a good early crank.....but it weighs 73 lbs
PostPosted: Fri Apr 29, 2016 2:49 pm
Not helping you now, but when I got a crank reground I had the machine shop supply bearings too..........
PostPosted: Fri Apr 29, 2016 4:20 pm
Any shops down there do crank welding? Have it built up and turned back to standard.
PostPosted: Fri Apr 29, 2016 6:08 pm
Early (forged crank) main bearings are 1.027 inch wide (26.11mm)
Late (cast crank) main bearings are 0.881 inch wide (22.38mm)
PostPosted: Fri Apr 29, 2016 6:43 pm
Have you tried the Oz Mopar Market board for a crank?
PostPosted: Fri Apr 29, 2016 6:47 pm
Thanks everyone for all your help but I have finally found some for forged crank from the same guy who had the cast bearings for sale.so all the best guys.from down here in Australia,mopar or no car.
