It is currently Thu Jan 01, 2026 3:21 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Slant 6 bearings
PostPosted: Fri Apr 29, 2016 7:09 am
Thanks for that,but wa means Western Australia
PostPosted: Fri Apr 29, 2016 8:09 am
Ah, okay, then it's a bit harder for most of us in Oregon and Washington to lend a hand with a heavy part.
PostPosted: Fri Apr 29, 2016 9:27 am
Id give you a good early crank.....but it weighs 73 lbs
PostPosted: Fri Apr 29, 2016 2:49 pm
Not helping you now, but when I got a crank reground I had the machine shop supply bearings too..........
PostPosted: Fri Apr 29, 2016 4:20 pm
Any shops down there do crank welding? Have it built up and turned back to standard.
PostPosted: Fri Apr 29, 2016 6:08 pm
Early (forged crank) main bearings are 1.027 inch wide (26.11mm)
Late (cast crank) main bearings are 0.881 inch wide (22.38mm)
PostPosted: Fri Apr 29, 2016 6:43 pm
Have you tried the Oz Mopar Market board for a crank?
PostPosted: Fri Apr 29, 2016 6:47 pm
Thanks everyone for all your help but I have finally found some for forged crank from the same guy who had the cast bearings for sale.so all the best guys.from down here in Australia,mopar or no car.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 2 guests
