It is currently Mon Dec 29, 2025 12:14 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Wed May 04, 2016 2:41 am
Hi.
Yes ! I have checked for timing chain wear, and I haven't find any slopping out of the normal I have seen in others S6 of the time without problems.
Also the first check I did was for the harmonic balancer sliping. I get an error of 2 degree retarded. I did new marks with paint between the internal and the external harmonic balancer rings and do the timming with it.
This afternon I go to make some trials with severals springs I have made, and take note of the spring lever number and vac pot number
Thank you in advance.
You need a SL6 to smile.
PostPosted: Wed May 04, 2016 10:28 am
Our member bigslant6fan has distributor spring kits, send him a pm.
http://slantsix.org/forum/privmsg.php?mode=post&u=4774
Some links you may want to browse:
http://slantsix.org/forum/viewtopic.php?p=330905
http://slantsix.org/forum/viewtopic.php?p=328519
http://slantsix.org/forum/viewtopic.php?p=319169
http://slantsix.org/forum/viewtopic.php?p=288143
Olaf
Aspenized
PostPosted: Wed May 04, 2016 2:23 pm
Wow. Very usefull info in those posts, and the source for the springs.
I will try to asimilate the maximum posible information.
Very good and detailed work.
Thank you.
