It is currently Wed Nov 25, 2026 5:44 am
 Post subject: No start
PostPosted: Wed May 11, 2016 2:42 pm
I just got my engine installed back into the car. I have power inside the car. When I hit the ignition key no power. I'm not sure where all of these wires hook up. Any ideas?
PostPosted: Wed May 11, 2016 3:32 pm
Man, that's a fire waiting to happen, why didn't you fix that when the motor was out? You wouldn't be having the problems you are.
PostPosted: Wed May 11, 2016 4:16 pm
I couldn't find a wiring harness for my 63
PostPosted: Wed May 11, 2016 5:01 pm
Um…the problem still needs fixing. You can get a new engine wiring harness for your '63 from www.evanswiring.com -- you'll want to have them add a fusible link.
And yes, this needs to be a right-now priority before your car burns up.
PostPosted: Wed May 11, 2016 9:35 pm
does the solenoid in the first picture need to be bolted down to get a ground connection to fire it? I can't remember. I also agree you need to rewire. my 73 had a wiring meltdown before I bought it and repairing it now will be much easier than repairing it if it fuses into an unrecognizable pile of rubber.
PostPosted: Thu May 12, 2016 7:28 am
What are all the plugs for?
PostPosted: Thu May 12, 2016 8:57 am
Well you obviously aren't looking hard enough, there's plenty of sources are out there!
PostPosted: Thu May 12, 2016 9:26 am
There are No complete harnesses for a 63. The guy recommended above needs my harness to make one. I can get a universal harness for the car.
PostPosted: Thu May 12, 2016 9:35 am
So...send him your harness. Or buy a '64 harness from him, which will work either directly or with utterly minimal alteration. You do not have a choice here, you need a new wiring harness.
PostPosted: Thu May 12, 2016 11:09 am
I just contacted him, he won't do a complete harness, only engine and head lights. Any other ideas? Will a universal one work?
PostPosted: Thu May 12, 2016 11:14 am
Maybe you have a different internet source than I have, please send a link to the ones you found. Thanks
PostPosted: Thu May 12, 2016 12:21 pm
You really need to learn how to use the "SEARCH" function! Lazy people! Good Luck
https://www.google.com/search?sourceid= ... xKzxgc-_Vc#
https://www.google.com/search?sourceid= ... ng+harness
http://www.ezwiring.com/store/index.php
http://www.evanswiring.com/catalog.htm
PostPosted: Thu May 12, 2016 1:34 pm
All you appear to need is an engine harness. Have him make that one for you, with a fuselink added. Headlamps you can do up yourself as per here.
PostPosted: Thu May 12, 2016 2:39 pm
Also the piece that is going into the firewall isn't burnt, it's cracked off. But as far as the ballast resistor, how does it hook up? Any pics?
PostPosted: Thu May 12, 2016 4:53 pm
Buy a FSM. (Factory Service Manual)
http://www.ebay.com/itm/like/2212759469 ... noapp=true
1964 Dart GT
