It is currently Thu Jun 04, 2026 4:30 am
Post new topic  Reply to topic  [ 62 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Thu Oct 15, 2015 9:50 am
a year, minus 4 days from when I started re working this car, a car that has basically sat in storage from 1980, and possibly from 1974,
I got it down a drag strip
https://www.flickr.com/photos/13718356@ ... 7563183853
Took it to the Lucas Oil RaceWay's Wild Wednesday Test and Tune,
and got it there towed by the 83 D150, which is another success.
http://www.lucasoilraceway.com/events/2 ... dnesday-2/
About the test and tune
my first time to run on the strip there.
maybe a 100 to 130 cars, lots of new Mustangs, Camero's , Challengers, saw one HellCat in the street tire group.
nice collection of 60's and 70's cars in the slick tire section, one guy had a Boss 302 in a Miata,,
the track got oiled down twice, but I got 2 runs in between 6:00 and 8:00,
talking with other racers, they said that is not that common to have that much down time, lot of nice friendly folks.
The first run, I was wanting only to get down the track in one piece with nothing falling off the car, with all the work done on the car, my only other test drive was a drive way burn out and a drive around the cul de sac. Well I let off the throttle twice and still went quicker than I ever did in the D150,,
Went back around, waited through another track clean up and made a second run,,, Moving along pretty well and noticed that the RPM's were pretty high, let off the throttle, looked down and noticed I had the auto selector in second, pushed it forward, tranny shifted to third and finished the run. A little quicker than the first one.
Two runs complete, nothing fell off, broke or leaked,
good day for me.
About the tow:
I built the D150 with the plan to tow the Barracuda,
and it did fine, never felt like the trailer was pushing the truck, stopped good, when going through the rebuild found that Dad had got this truck with a higher capacity than stock front axel and larger front and rear brakes, maybe like a heavy half ton package...
When pulling from a stop on an uphill grade, needed to slip the clutch a bit to get it rolling (3.21 rear axel), once it starts rolling, give it some gas and it pulls away. Pulling from level stops is fine.
so there it is,, The 68 Barracuda made it down the track and the 83 D150 pulled it there and back,, all without issues,, been a good day! :D
PostPosted: Thu Oct 15, 2015 10:08 am
Big congrats, John! Must feel like a million buckaroos.
But, you are killing us drag racers... What did it run?! We all know you will run a second or two faster when all is polished.
PostPosted: Thu Oct 15, 2015 10:23 am
Congratulations on both vehicles! Must be a great feeling to have TWO successes!
PostPosted: Thu Oct 15, 2015 12:51 pm
What did it run?!
1) stock A body, with the interior stripped out, no additional lightening
2) stock: OE bores, pistons, bearings and valves, raised compression to 8.4, a nice exhaust header, super six carb and intake, with a super secret cam
3) stock 904 and converter, 3:55 rear gears
what should it run ?
I got something to toy with this winter,, and have fun with for years to come. There will be time slips.....
PostPosted: Fri Oct 16, 2015 9:03 pm
17:38@80
PostPosted: Fri Oct 16, 2015 10:06 pm
wow....thats a lot of stuff to come together at once. Good work!
PostPosted: Sat Oct 17, 2015 7:09 am
17:38@80
that seems to be within the realm of possibility
the second run,, where I hung in second gear for much of the run went down like this
R/T .741
60' 2.510
330 7.420
1/8 11.656
MPH 56.95
ET 18.349
MPH 74.79
PostPosted: Sat Oct 17, 2015 7:22 am
The important part is you made it there and back with no breakage. The speed will come later. :D
PostPosted: Sat Oct 17, 2015 5:24 pm
exactly.
Logistics and consistency will triumph over horsepower and dollars....
PostPosted: Mon Nov 16, 2015 4:11 pm
plans for the winter,,
1 ) build a reliable 904..
2 ) put it in the 68 Barracuda
sounds simple enough,,
the 8.75 rear and sure grip is rebuilt
the engine is a work in progress
the OE tranny is an opportunity for improvement
picked up a spare 904, s/n traces to a 1974 198/225
took it apart down to the case today,
https://www.flickr.com/photos/13718356@ ... 0522634988
called A&A, dropped Wayne V's name a few times,
lets see where this goes,
what I am looking for is, a 904 that meets these requirements:
1) supports a max of 300 HP
2) demonstrates run to run consistency
3) is built for season to season reliability
4) provides value
I want the 68 Barracuda to be a fast 4 speed street car, for now it will be an auto strip car, let's see where this goes..
PostPosted: Wed Dec 09, 2015 5:18 pm
Very cool car!
"Safe place", I've done that before. :lol:
'78 Volare 225
'67 Charger 318
PostPosted: Thu Dec 10, 2015 9:18 am
Great John,
904's can be built to handle about 1000 HP - Ask Rick at A&A - 300 should be a breeeeeeze!
Can you send me some pics of the rear band on that trans? or even the rear of the inside of the case?
Doing some research.
PostPosted: Sat Dec 12, 2015 7:05 am
Greg, I would, but everything is at A & A,,
I had told them I would need it back till Jan - Feb,,
PostPosted: Sat Dec 12, 2015 1:46 pm
My '67 Valiant 100 with full interior, stock '67 short block (including cam), big valve head, 8.5:1 compression, Offy intake, Holley 390 carb, cleaned up stock exhaust manifold, 2.25" full exhaust, 3.21 gears and column shifted 3-speed manual would go 17-flat most places and went 16.88 at Woodburn.
No headers, no cam change.
At Redding one year I drove Sergio's '68 Dart and it ran about the same ET as my Valiant, but at less weight as it had a stripped interior. Stock motor aside from the Super Six and headers.
If you are chasing a lower ET I would get an adapter to run a big Holley 2 bbl and match the adapter to the intake. Epoxy and grinding will be needed for a good match. A big 2 bbl from a 360 or 400 are also fine choices and may even best a Holley in driveability.
PostPosted: Wed May 25, 2016 6:08 pm
The fuel injection install is complete
the car starts, idles fine,
here is a link to the fuel injection thread for this car
http://www.slantsix.org/forum/viewtopic.php?t=59051
to do any real FI tuning I need to get the car on a strip or dyno,
prior to running the car hard, I was needing to upgrade the tires, and now that box is also checked.
https://www.flickr.com/photos/13718356@ ... 8113263980
Tires are 215x60x16,,, 40K Michelin tires that came off the wife's Altima when she wanted new tires at the start of last winter. Plenty of life left in those tires for what I'll be doing with them.
Wheels are Torque Thrust II
16x7 4.0 backspace on the front
16x8 4.9 backspace on the rear
front wheels, 15.5 lbs
rear wheels, 17.5 lbs
and today I finished the install of an electric trailer brake controller on the 83 D150,,still trailer shopping...
