It is currently Wed Nov 25, 2026 5:21 am
 Post subject: overcharge & HEI
PostPosted: Sun Jun 19, 2016 10:51 am
I burned out a module and discovered the charging system overcharging. My module gets its juice from the batt terminal on the alternator through a relay.
Either the voltage regulator is bad or I have a grounding issue. I haven't looked into it completely yet. I was just wondering if my work on the overcharging issue will fix my burned module problem.
I've not had any issues with my HEI conversion for months/thousands of miles! Was hoping that repair would address the other.
I found this link helpful in understanding the D charging system.
http://ramchargercentral.com/electrical ... ng-system/
Thanks guys and happy motoring
PostPosted: Sun Jun 19, 2016 12:07 pm
Yes, overvoltage and/or spiky output will hammer the module.
PostPosted: Sun Jun 19, 2016 12:32 pm
Thanks for the verification Dan!
PostPosted: Mon Jun 20, 2016 5:59 am
Did all the necessary testing for the appropriate grounds & all is well there. On engine start up it is charging @ 14.5v. Then continues to climb. I shut it down @ 19.5v in fear of toasting another module.
I'll pick up a VR today.
Any recommendation's for a regulator. I'll probably go with NAPA if there are no other recommendations.
PostPosted: Mon Jun 20, 2016 11:04 am
Which type of charging system? Up to '69 "Single field" or '70-up "dual field"?
PostPosted: Mon Jun 20, 2016 11:40 am
Yes its dual field, sorry, I should have clarified that.
PostPosted: Mon Jun 20, 2016 12:01 pm
Tough to get reliably good quality on the open market these days. Genuine American-made Mopar items can be had from Old Car Parts Northwest.
PostPosted: Tue Jun 21, 2016 5:28 am
I ordered a regulator from Old Car Parts NW. Be here in a few days @ 13 + 3 dollars shipping and some change. Probably worth it @ twice the price.[/url]
 Post subject: mopar regulator came
PostPosted: Wed Jul 13, 2016 8:44 pm
3 days after I ordered it. I can't believe how much comfort I took in seeing a regulator with the Mopar symbol on it.
Installed it and checked the voltage. It had settled down to 14.3V. I've driven 100 miles or so and no issues.
Thanks again
