It is currently Sat Apr 25, 2026 4:08 am
PostPosted: Sun Mar 28, 2004 8:00 pm
Are there any problems with running aluminum wheels on the street? I would like to hear from anyone who is doing this.
Bob D
PostPosted: Sun Mar 28, 2004 8:14 pm
like these?
 Post subject: Not really....
PostPosted: Sun Mar 28, 2004 8:18 pm
Even modern rims are still light and good, but....I have a buddy with a tow company and I've seen the mags and aluminum rims on newer cars literally shatter when a blowout occurred or they hit a pot hole on a low tire at speed. Rims like 70 Valiant has are pretty durable, but the aftermarket, 'skinny' ones are a 'watchout' item if you have an 'emergency'....
just FYI,
PostPosted: Sun Mar 28, 2004 8:21 pm
like these?
*presses "I like" button repeatedly*
DING DING DING!!!!
PostPosted: Mon Mar 29, 2004 3:21 am
I run alloys on one of my Valiants and I have run them on other cars I have owned and never had a problem. Some of our roads here in Australia aren't very good, so you just have to be a bit carefull at times.
94 Falcon 4.0 auto
70 Valiant 265 Hemi auto
70 Valiant 318, 904, Coupe
69 Valiant 225 auto x 3 (1 sedan, 2 coupes)
64 Falcon 250 2V auto
yes, I have too many projects.
PostPosted: Mon Mar 29, 2004 10:15 am
I run American Racing Outlaw II's on my 63 Dart without any problems.
http://public.fotki.com/BlueJ/63_dart_man_toy/
Kevin
PostPosted: Mon Mar 29, 2004 12:41 pm
Aluminum wheels are fine as long as they are made properly. A taller tire helps with the pot hole issue.
PostPosted: Sat Apr 17, 2004 12:11 pm
My Dart and both my other cars run aluminum wheels. I believe the aluminum street wheels on my 206,000 mile F*rd Probe are the originals, although I can't confirm this. They can hold up pretty well.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Apr 17, 2004 3:16 pm
I'm rather fond of my aluminum wheels on the old 66.... There are as many safety concerns with aftermarket aluminum wheels as there are with aftermarket steels. Any low profile tire, and a pothole at speed can wreck a rim. I've seen tires blown off of just as many steel wheels as I have aluminums.
Brett
1963 Valiant Vert(225 /6)
1964 Dart GT Vert(225 /6)
1965 Dart GT (273)
1966 Barracuda (273)
1966 Dart (225 /6)
1970 Charger R/T (440)
1972 Satellite 4 door (318)
1974 Valiant 4 door (318)
1981 Ramcharger (318)
1987 RamVan (225 /6)
PostPosted: Sat Apr 17, 2004 8:44 pm
i'm pretty sure that 70valiants aluminum slots are sm bolt pattern,but what about BrettK and dart63's ??? Does anyone know if companies are stiill making rims for the small bolt pattern ????
PostPosted: Sat Apr 17, 2004 9:31 pm
Mine are LBP.... the suspension under the 66 was donated by a 76 Duster.
Brett
1965 Dart GT (273)
1966 Dart (225 /6)
PostPosted: Sun Apr 18, 2004 1:09 pm
Yes mine are sbp. hopefully they will be for sale by the end of summer.
I'm going to bbp disks and have a bbp 7 1/4".
 Post subject: What wheels are those??
PostPosted: Mon Apr 26, 2004 10:14 pm
What kind of wheels/size are on that nice '65 Coronet?? And tires?
A similar setup on my Valiant convertible would look awesome, I think. :)
PostPosted: Tue Apr 27, 2004 9:06 am
I assume you're referring to my '65 Coronet? If so, those are Fikse rims. 17x10 in the rear and 17x8 up front. Rear tires are 315/45-17. Better spend some time moving sheetmetal around to make room for them!
PostPosted: Thu Apr 29, 2004 8:09 pm
I thought they looked like Fikse. Moving metal is not a problem... my quarters are in need of corrosion repair, and I'm probably going to play with the inner tubs a bit for more room while things are apart... funny you should mention spend... Fikse wheels aren't exactly cheap... I'll have to stick with black 15" steel rims with the original dog dish for now, I guess. I wish they were lighter.
1965 Valiant Custom 100 Convertible
