It is currently Wed Nov 25, 2026 3:56 am
PostPosted: Fri Jul 22, 2016 2:08 pm
After rebuilding my distributor and setting point gap to .019, when I try to start it, it doesn't run on its own, and when I turn off the starter, there is major backfire through the exhaust. Please help
1968 Dodge Coronet with the original 225 slant six and a904 torqueflite transmission. One family car with 67k original miles and mostly original parts.
PostPosted: Fri Jul 22, 2016 7:00 pm
What is the engine timing set at? Firing with an open exhaust valve indicates that spark is way late,, maybe the distributor is a tooth off.
PostPosted: Fri Jul 22, 2016 8:31 pm
Thanks for the info, after reading up on it a little more I found out that it was probably a few teeth off. so after some trial and error I finally got it running
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 2 guests
