It is currently Fri Jun 19, 2026 4:51 am
 Post subject: Need advice
PostPosted: Tue Sep 13, 2016 8:45 pm
Okay so I took the head off my engine because the head gasket blew. It is the origional head gasket from when the car was sitting up for 30ish years.
I have gotten the head redone, and gotten all the parts i need to proceed with reassembly, but I see a little dip on the number six piston tunnel.
here is a picture;
http://s17.photobucket.com/user/jase232 ... 1.jpg.html
So is this a problem? If so what do I need to do?
PostPosted: Tue Sep 13, 2016 10:56 pm
You talking about the nick about 10 o'clock on the bore?
PostPosted: Wed Sep 14, 2016 9:50 am
Yes I am actually.
PostPosted: Wed Sep 14, 2016 2:50 pm
If the ring isn't going to get that high, smooth it off and run it.
PostPosted: Wed Sep 14, 2016 4:15 pm
what do i smooth it off with?
PostPosted: Wed Sep 14, 2016 6:11 pm
The little sanding disks on a dremel (they have some give)
Use fine.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Darcy225 and 2 guests
