It is currently Sun Nov 08, 2026 12:44 am
 Post subject: BBD carb ID list?
PostPosted: Sun Oct 02, 2016 3:27 pm
Car Model: 62 Lancer GT
I have found a lot of info on BBD's searching on this site. But is there a list of BBD numbers and there applications, usually someone posts numbers and then someone ID's it for them. I have adopted 10 BBD's (one has Holley stamp) and 1 BBS only 3 have tags. There is a 6365S a 6262S and a 4808S. I have been able to ID 3 as Super Six by using the BBD manual. Did the BBS have tags? If so is there away to tell them apart without tag? Thanks in advance for any help!
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
 Post subject: Re: BBD carb ID list?
PostPosted: Sun Oct 02, 2016 3:55 pm
Without a tag, you cannot identify a Carter carb. The numbers stamped or cast onto the various castings do not help.
4808S: ???
6262S: ???
6365S: '73 Dodge truck with 318
The lists I usually consult are here (passenger car) and here (truck).
PostPosted: Sun Oct 02, 2016 5:02 pm
Thanks! I'll probably post some pics of some of them in "for sale" if anybody wants them.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Sun Oct 02, 2016 5:07 pm
Good idea. If you post as many angles as possible (top view, bottom view, all four sides) it will probably be possible to at least get close to a useful ID on some of them.
PostPosted: Tue Oct 04, 2016 4:29 am
Not that this would be the definite word, but I was watching a cool Chrysler training film online that compared the super 6 carb to the 318 carb.....the cutouts/slots in the grooves on the bottom of the carb are one giveaway. The 318 BBD has one continuous groove on either side of the throttle bores on the mounting surface for vacuum and the super 6 has the same grooves except they also have a "notch" at the apex of each groove....
https://www.youtube.com/watch?v=45uHX9ceSwM
PostPosted: Tue Oct 04, 2016 7:10 am
Thanks, I did use a link that had the same info in printed form , 3 of the carbs are super six, 1 is a BBS (unsure of application) and the rest are unknown look like 318 but completely different variations. One is a Holley version. I will post pics when I get a chance. If someone needs carb or parts cheap!!!
1966 Dart GT
62 Lancer GT
B Body 8 3/4
