It is currently Sat Nov 07, 2026 3:47 pm
PostPosted: Mon Sep 26, 2016 12:24 pm
Was speaking with Ken from Oregon Cams today. He mentioned a cam he's currently working on for a gentlemen that a more aggressive than the RV10/295. Asked him to email the numbers but was wondering if this gentleman is here on these forums or if there is a post about this? For those who watch these forums more than a newly joined user. Thanks.
PostPosted: Mon Sep 26, 2016 12:48 pm
Perhaps he's referring to the RV15.
PostPosted: Mon Sep 26, 2016 2:24 pm
It's probably a shorter path to getting what you want if you declare your desires. It may be that the cam Ken is grinding is something I came up with for another member here, but then again maybe not.
 Post subject: Yep...
PostPosted: Mon Sep 26, 2016 4:18 pm
x2 here, if you know what you want or are going to do it's easier for Ken to recommend a bumpstick...
It's tough to say what Ken is working on, they do a fair bit of slant six work from mild to wild... thankfully it's not my cam he's working on, it wouldn't work in your build... without lots of mods.
PostPosted: Tue Sep 27, 2016 8:20 am
No it's not the RV15. Asked Ken before about that cam. He has nothing on that cam. I'll just wait till I see the numbers on the cam.
PostPosted: Tue Sep 27, 2016 9:47 am
The cam I cam up with for Zach's street performance 225 is this:
OCG #1416 intake lobe and #819 exhaust lobe on 108° lobe centers. This gets you 258/248° advertised duration, 226/219° duration at .050" tappet rise, .459/.437" gross lift. We're targeting a 103° installed centerline.
With an intake closing point in the 48-52° range depending on valve lash, installed centerline, etc the engine will need to be 9.2:1 static compression for an 8:1 dynamic compression ratio.
This build is using a trick 390 CFM Holley (not the list 8007) dual Dutra Duals, a 4-speed, etc, etc.
PostPosted: Tue Sep 27, 2016 5:22 pm
Car Model: 66 Valiant, 82 D150, 94 Ram 2500 TCD, 69 Dart
DtEarth,
I am probably the guy you are looking for. Josh was instrumental with cam grind details for my build.
This is going in a 66 Valiant that, at the moment, is dead stock. I'm going to keep it in sleeper mode, so unless you notice the 4-speed tranny or bigger rear tires, it will look like Gramma's Grocery Getter.
The bottom end is a stock 225 build with few miles, .040 overbore. I'm putting on the mentioned Holley 390, an Offy intake, dual Dutra duals (2-into-1 setup with a Flowmaster muffler), HEI electronic ignition, roller timing chain, and getting the head worked on with a moderate porting job, bigger valves, and milling to raise the compression. Compression is planned as listed, 9.2 static for 8.0 dynamic.
I have no illusions about being the fastest gun in town. However, it should shape up to be a fun driver that may surprise a few people.
As info, I'm also upgrading to front disc KH brakes, all new front and rear suspension, shocks, sway bars, etc. It will be a busy winter in the shop, for sure.
Zach
PostPosted: Wed Sep 28, 2016 9:57 am
Also, the OCG #346 (about 8° longer duration) was a consideration, but torque was prioritized and so the Offy intake and a milder cam were chosen.
PostPosted: Mon Oct 03, 2016 9:56 am
