It is currently Thu Aug 13, 2026 2:15 pm
Post new topic  Reply to topic  [ 166 posts ]  Go to page Previous 18 9 10 11 12 Next
PostPosted: Sat Sep 03, 2016 10:22 am
The Fuel line mod "recipe" has been updated: broken links updated and a new option added for the 90° fittings.
PostPosted: Thu Oct 13, 2016 3:20 pm
So I went out to buy fuel line as in the recipe..can't find r9, just r7.....and it's cheap...soni know it is wrong. Lol
Napa has hose that is like 4.50 a foot....but no r9 marking....they are marked as follows:
Biofuel, diesel, ethanol, methanol compatible ...carb q09019a
4219bf
Epa compliant 15 grams
Fgtsplinebf1
Gates
Could this be the right stuff or keep looking?
Never figured FUEL HOSE would be my next stumped moment.....lol
PostPosted: Thu Oct 13, 2016 7:25 pm
Gates SAE 30R9 (4219D) fuel injection hose
1964 Dart GT
PostPosted: Fri Oct 14, 2016 5:10 am
Ok so, what they have at the napa store is NOT the right stuff.....dangit.
I am out of options localy for the most part.
PostPosted: Fri Oct 14, 2016 5:50 am
Called Oreileys and they have sae 30R14
What about this?
http://www.oreillyauto.com/site/c/detai ... &ppt=C0222
PostPosted: Fri Oct 14, 2016 7:25 am
That'll be fine.
PostPosted: Fri Oct 14, 2016 9:44 am
Which...the 4219bf or the 30R14?
PostPosted: Fri Oct 14, 2016 11:56 am
30R14 Barricade.
 Post subject: hose at Amazon
PostPosted: Sat Apr 29, 2017 5:39 am
Car Model: 1974 Dart Swinger 225
Continental Elite 30R9-5167 is a 7-foot length of 5/16" ID fuel injection hose, with 4 clamps, for $23 at Amazon.
PostPosted: Tue Dec 19, 2017 10:55 am
I want to ask about the location of the fuel filter after this mod.
1966 dart sedan.
I have a small bit of hose coming straight up from fuel pump (the orig mech pump), then into the metal fuel filter then hose up and over the valve cover over to the carb.
The location of the fuel filter is so close and touches the #1 spark plug wire. It is also a few inches away from my HEI setup which is inches away from the main output of the Alternator.
Is there any issues with the wires being so close to the fuel filter? or fuel hose?
Or should I put the filter lower, like maybe 1 inch from fuel pump? that would put it lower than the alternator and plug wires
66 dodge dart 270, 225ci, 3.7l, L6
PostPosted: Tue Dec 19, 2017 5:55 pm
I wouldn't worry too much about it. Maybe lower it a bit next time you change the fuel filter.
PostPosted: Wed Dec 20, 2017 6:41 am
I usually have the fuel filter up higher where I can zip tie it to the heater hoses (or the heater hose bracket on the valve cover), but if you're concerned with appearance this probably isn't the best way to go.
Escape Velocity Racing
PostPosted: Thu Aug 11, 2022 2:42 pm
…there was this attachment you could buy. These instructions have a manufacturer address with a postal zone, and those were replaced by ZIP codes in 1963, so that plus the mid-'50s car profile gives some idea of the era. Looks like a close ancestor of the 3-nipple fuel filter used in the Ultimate Xtreme Stage-2 version of the fuel line mod: a chamber for vapour to be separated from liquid fuel, and provisions to send the vapour back to the fuel tank. My best guess is that inside the can, the inlet from the fuel pump is near the top and the output to the carb is at the bottom, and there's a small orifice—maybe 0.045" or so, like the one in the 3-nipple fuel filter—in the vapour outlet. The saddle clamp for the fuel filler pipe reminds me of the quick-'n'-dirty ones used to tap into a cold water line for an icemaker or whole-house humidifier, or the puncture-type side taps for cans of refrigerant. I learned of this item from a blurb about the 1973 AMC police cars; its mention made me go looking and I found the instruction sheet. Don't know that the kit used by AMC was the same as the older kit in the instruction sheet, but seems plasusible.
PostPosted: Sat Mar 23, 2024 6:55 pm
Car Model: Valiant Signet
Just installed today, I think it looks clean.
PostPosted: Sun Mar 24, 2024 6:27 am
You might consider replacing long sections with metal line for safety reasons.
Rubber fuel hose on either end to connect the metal line to the carb. Or better yet bend up some appropriate 5/16" fuel line with the appropriate flares and fittings from fuel pump to the carburetor.
Best of luck!
Users browsing this forum: Bing [Bot] and 8 guests
