It is currently Wed Jun 24, 2026 8:00 pm
PostPosted: Mon Apr 05, 2004 12:45 am
i've been thinking about changing my breather for quite some time and haven't found anything so i'm looking at doing this myself i've been looking for a open filter breather for the 2 barrel all i've seen are for the 4 barrel so i am thinking of cutting the sides off my stock breather and was wondering what i might find after doing such a thing
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Apr 05, 2004 9:29 am
Are you talking about your air cleaner? Mr Gasket makes adapters to go from a 4bbl size to a 2bbl size. If your talking about the crankcase breather, Mr. Gasket, Edelbrock, or Spectre makes open breathers that work in a slant valve cover. I have a Spectre on mine now.
PostPosted: Mon Apr 05, 2004 2:32 pm
yes i am talking about my air cleaner thanks for the tip on how to get one to fit but i'm cheap why buy it when you can build it right
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Apr 05, 2004 8:08 pm
Thats what I plan to do when I switch to my open air cleaner. The plastic adapters crack over time. On the other hand, they do give a smooth path for the air to flow into the carb.
PostPosted: Mon Apr 05, 2004 9:11 pm
i looked it over and it looks quite simple but looks can be deciving
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Thu Apr 08, 2004 11:40 pm
i have my engine, carb and tranny in some degree of dismantle so i'm not really sure on what lines will go into what ports it has never been together from the day i bought the truck mind you i did tear it all apart for the most part
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
Users browsing this forum: Google [Bot] and 7 guests
