It is currently Fri Nov 20, 2026 7:00 am
PostPosted: Mon Nov 28, 2016 2:16 pm
Molasses works but as any such solution you have to work quick after the
rinse to stop flash rusting. Evaporust flat out rocks! And protects the metal
against rusting when you're done. I did a set of GLH coils by wire wheeling
them 1st, then putting them in a 3gal. bucket of ER, using water filled jug/
bottles to displace the volume so I didn't need 3 gal of product. Perfect
results.
Good to know it works diluted. I am going to give it a try soon.
 Post subject: ditto
PostPosted: Mon Nov 28, 2016 2:30 pm
I second Killer6's dilution story, I took two gallons and diluted to about 50 gallons with water and soaked my whole K-frame in a big tub. It takes a little longer, but works the same, completely removes all the rust.
http://s785.photobucket.com/user/67dart ... rt=3&o=307
Parts go in like this: http://s785.photobucket.com/user/67dart ... rt=3&o=335
And come out like this: http://s785.photobucket.com/user/67dart ... rt=3&o=333
brian
https://tinyurl.com/yynpj4v2
PostPosted: Tue Nov 29, 2016 6:44 am
Cool. Thanks for the results, folks.
 Post subject: Re: ditto
PostPosted: Tue Nov 29, 2016 7:51 am
brian
Those look amazing. I'm definitely going to do that with my suspension pieces. Possibly my exhaust manifolds too, then get them coated pronto.
PostPosted: Tue Nov 29, 2016 6:05 pm
results.
While it does work somewhat diluted, albeit a tad slower, I was stating
that I set sealed containers full of water in the bucket to displace airspace.
That allows you to use much less solution to cover the piece.
 Post subject: evaporust
PostPosted: Tue Nov 29, 2016 8:42 pm
NOTE: if you leave evaporust on the part and let it dry it may turn dark, but that is a passivation layer only, it comes off if you scrub it. I discovered this when I was soaking some spindles and part of the spindle was sticking out of the solution (cause I was soaking rims underneath it). The area that had evaporust on it that was exposed to air turned dark, but I took some 0000 steel wool and it came off.
I've found the best way is to make sure the part is completely submerged, and when you take it out, rinse it immediately and dry it. No worries.
FYI,
Brian
 Post subject: Re: evaporust
PostPosted: Tue Nov 29, 2016 10:06 pm
In hot water, which makes dry-off a lot faster and more complete.
 Post subject: Right Dan,
PostPosted: Tue Nov 29, 2016 11:01 pm
I usually hit the part with a heat gun to dry it off, but hot water is a good choice as well. I don't see any flash (rust) layers for that reason, good point.
brian
PostPosted: Tue Dec 06, 2016 4:30 pm
If the engine is still in the vehicle and driveable, use oxalic acid to remove the rust. Oxalic acid will not remove solder bloom; a different product is needed for that. Prestone used to have a "heavy duty" radiator cleaner; the acid part was oxalic acid and the neutralizer was sodium carbonate (a/k/a washing soda). I picked up a 50 pound sack of oxalic acid a few years ago. If anyone needs some, PM me.
Ken
PostPosted: Wed Dec 07, 2016 5:56 am
The bulk of it came out with a good pressure washing. It's too cold right now to work on it, but I think the evaporust will take care of things. This engine has cured me of ever using just straight water!
Users browsing this forum: Google [Bot] and 9 guests
