It is currently Fri Nov 20, 2026 4:33 pm
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 14, 2016 9:51 am
Headwork and oversized valves are the biggest gains you can spend your money on. Followed by intake and exhaust.
head work - I'm having this put on this winter. Did this last year but never had time to get it installed. I did all the porting and valve multi-angle cuts, local shop did the oversize valve install and head milling. http://www.pbase.com/spacecommander/dodge If you look at some of the pictures of the original ports - you can see how horrible they are.
That head looks good in the after pictures. I agree, the biggest detriment to power on the slant six is the head. I did a little port work on mine and burned up a Dremel tool doing it, but when I added a 2bbl and dual Dutra exhaust it really woke it up.
PostPosted: Thu Dec 15, 2016 4:43 pm
I burned out a dremel too and got a flexible shaft one that really worked great - even though it was a Hazard Fraught (Harbor Freight) Tools special. ;-)
Tom
'86 Alfa Romeo Spider, red "Dinsdale"
'10 Corvette, red "" (no name yet)
'95 Ferrari 348, red "Zoom"
'04 Maserati, black "Evil"
'05 Aston Martin DB9, green "Bond, Treasury bond."
'82 Dodge W150 Power Ram, yellow "E. Valdez"
 Post subject: Too light...
PostPosted: Thu Dec 15, 2016 6:19 pm
Dremel is too light but works OK for polishing where needed, to do the job right you should have a set of 3/8" shank die grinding balls/flames/etc and one set with extended shafts... my poor 31 gallon air compressor barely keeps up with a full port session...
A stock engine street port would take a couple hours to complete all the ports... a little longer for the next step up, 230HP build about 8 hours... on my last 2 heads I spent about 12 hours on them... just to give you a time estimate...
 Post subject: RE: Spacecommander
PostPosted: Sat Dec 17, 2016 6:11 am
Car Model: 1968 Barracuda - Fastback
@Spacecommander, your pictures are excellent - thank you for going through the troubles of documenting your progress/process, it will really help me to plan for my work! -Chris
@DusterIdiot - much appreciate the time references. 230 is the goal. New tools are also on the list (Yes!).
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Sat Dec 24, 2016 8:17 pm
You are talking at the crank, right? 8)
Users browsing this forum: Google [Bot] and 8 guests
