It is currently Mon Jun 22, 2026 4:56 am
PostPosted: Wed Apr 07, 2004 6:01 pm
Heh... Ive seen as much as a $.10 spread during my morning commute. :shock:
This is per litre of gas, remember.
PostPosted: Wed Apr 07, 2004 7:15 pm
Well I should clarify, the $2.11 was for chevron, cheaper stations like Valero, at the same time, are running 87 octane for $1.99 but I won't go near that stuff. Chevron or bust usually.
30 miles in one direction and you go up a few cents, 60 miles in the other direction (Silicon Valley) and your liable to go up a quarter :shock: .
PostPosted: Wed Apr 07, 2004 7:26 pm
guys i didn't put this up for a gas price comparison i'm trying to find something out how much compression before i can't run 87 octane
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Thu Apr 08, 2004 4:58 pm
Like I said I took 0.100" off and cant run 87 octane. I would think 0.060-0.070" would be ok
P.S. I spent $1.87/gallon for 93 octane today
PostPosted: Thu Apr 08, 2004 10:45 pm
Car Model: 1966 2D Dart
As many other things, my slant head was milled w/o measurements. The dynamic compression test (measured from spark plug hole when rotating the engine with starter) gives 1.2 - 1.3 MPa readings (174 - 188 PSI).
This is not too much for the 95E fuel sold here. As well I have not checked the timing mark, if it is located correctly or not. Timing light says, this engine has about 10 degrees on idle and 30-32 degrees at 3000 rpm up.
Fuel price 1.1 €/L (~5US$/USGal).
PostPosted: Thu Apr 08, 2004 11:02 pm
thank so i should be safe with 0.020 off both head and block and don't worry i was just being a smart ass and 75.2 last time i gassed up anything but thats canadian dollars and by the liter for 87 octane to boot if only gass prices returned to what they were 10 years ago
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Fri Apr 09, 2004 7:12 am
The block doesnt usually warp, so other than correcting deck height for race purposes, you don't really need to, plus it will wipe out your engine serial number. I would just check the deck surface with a feeler gauge and if it's good, leave it as is.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
