It is currently Tue Jun 09, 2026 5:37 am
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 162 63 64 65 66128 Next
PostPosted: Tue Jan 31, 2017 6:45 pm
Got the motor and transmission out, the K frame removed and the new one installed. Motor should be ready to set down in the car again in a few days! :lol: :lol:
PostPosted: Tue Jan 31, 2017 7:55 pm
That shore be purty, Rick. :D
PostPosted: Wed Feb 01, 2017 2:55 am
Coooool! 8)
PostPosted: Wed Feb 01, 2017 3:35 am
Nice work, Rick! Bet you can smell the 12s...
PostPosted: Wed Feb 01, 2017 5:07 am
Poser
Yep, nicely done Mr. Covalt.
PostPosted: Wed Feb 01, 2017 7:06 am
SSRN National Champion
Really like that K frame. looks real good.
PostPosted: Wed Feb 01, 2017 1:23 pm
Once the engine fires and has oil pressure, I'll start sniffing for the 12.99! :lol: :lol:
PostPosted: Wed Feb 01, 2017 3:10 pm
I removed the oil pump from the mild race engine that I pulled on Monday to check the oil pump and cam gears. I was excited to see two good gears after 3 seasons of racing. So once the race car is done I'll be doing another swap into my truck. :lol: :lol:
PostPosted: Thu Feb 02, 2017 6:14 pm
Looked at my Jeffrey head and the new intake/exhaust gasket and the intake ports are almost a perfect match as is. The intake runners are slightly smaller than the gasket so I am just leaving them as is. I lined up the manifold on the gasket and made a couple hash marks. Them I installed the gasket on the head with the intake to see how it lined up on the head. All appears to be fine!
I finished installing the Stage 8 fasteners on the oil pan so I dont have to worry about them coming loose. There is not enough in the kit to do the whole pan so I drilled the heads on some allen screws and used safety wire on the ends. I'm especially glad to know than none of them can fall out!. I've had that happen before and it makes a mess.
Rick
PostPosted: Thu Feb 02, 2017 6:50 pm
Nice! :D
PostPosted: Fri Feb 03, 2017 5:23 am
Rick, what intake gasket is that?
PostPosted: Fri Feb 03, 2017 12:53 pm
Cox brothers reissue by brian droschak
You can pm him here.
User name: Brian
PostPosted: Sat Feb 04, 2017 1:04 pm
Next time you see this it will be in a car!! :lol: Couldn't decide if I wanted the intake blue or silver. Blue it is!
PostPosted: Sat Feb 04, 2017 6:06 pm
Sure is nice looking :) :) :)
PostPosted: Mon Feb 06, 2017 11:08 am
Um, wow.
