It is currently Tue Jun 23, 2026 3:28 am
PostPosted: Thu Apr 08, 2004 9:59 am
Does the keyway and the timing mark line up on a stock harmonic balancer? In other words are they indexed the same? I am trying to determine if the outer ring on my harmonic balancer has slipped.
PostPosted: Thu Apr 08, 2004 1:43 pm
According to Damper Dudes, the mark is supposed to be 5 degrees off of the keyway. I'm not so sure I'd trust them though...
PostPosted: Thu Apr 08, 2004 2:14 pm
The timing mark is not in line with the keyslot.
Different years have the mark in different places but none line-up exactly to the keyway.
PostPosted: Thu Apr 08, 2004 2:20 pm
Doc, do you have a list of what it should be for various years? I flipped through the engine section in the service manual and couldn't find anything.
 Post subject: harmonic balancer
PostPosted: Thu Apr 08, 2004 2:28 pm
I have three balancers and all three have the timing marks in a different location. I do not know which one if any are correct and I can not accurately time the engine. Tomorrow I will get a gauge to find TDC and go from there.
PostPosted: Thu Apr 08, 2004 9:27 pm
The location of the timing mark (tab) is the "deciding factor" for the dampner mark.
In general:
60-67 had a bolt-on timing tab on the left side of the engine, the damper mark is at "1 o-clock" with the dampner keyway being 12:00
68-79(?) had the timing tab welded to the cover so it can be seen from the passenger (right) side of the car. The dampner mark is at 4:00
80 and up have a tube in the timing tab at TDC and the dampner mark moved slightly, kinda at 3:30
Best bet, use the positive stop methode to find true TDC and punch your own timing mark. I also punch two marks at 30 & 35 degrees so I can check the total timing without a fancy timing retard timing light.
PostPosted: Thu Apr 08, 2004 9:52 pm
I recently(two weeks ago) pulled grabbed a spare damper off a 1978 Aspen and it had the 'tube' type tab, FYI....
PostPosted: Thu Apr 08, 2004 10:51 pm
Doc, I have a 70something motor, but in any case the tab on the timing chain cover is on the passenger side.
You say the timing mark should be at 4 oclock. That means over 90 degrees of seperation.... :shock: That sure is way off compared to the 5 degrees I was quoted.....
