It is currently Sun Jun 14, 2026 11:38 am
PostPosted: Wed Jun 21, 2017 4:22 pm
Car Model: 1962 Dodge Lancer, 2dr post
Would anybody happen to know what the nominal cylinder wall thickness is on a 225?
PostPosted: Wed Jun 21, 2017 5:54 pm
Have you read the block article by Doug Dutra? http://www.slantsix.org/articles/dutra- ... blocks.htm
 Post subject: Thank you...
PostPosted: Wed Jun 21, 2017 7:02 pm
Thank you, Joshua Skinner for the tip on Doug Dutra's article
PostPosted: Wed Jun 21, 2017 10:05 pm
You bet. I'll add that some have found the early blocks to have thicker cylinder walls, but I don't have any direct experience there. None of my engine failures had anything to do with block problems, but I've never gone for large overbores either.
PostPosted: Thu Jun 22, 2017 9:49 am
Dutra's article pretty much tells me that the earlier 170 RB is the way to go. I have a great 225 setting here, but I might wind up prowling wrecking yards from here to Walla Walla looking for this 170 engine. I really appreciate your input. I'm finding out after 50+ years of playing with /6's, that I don't know nearly as much as I thought I did. :)
