It is currently Sat Jul 18, 2026 7:29 pm
 Post subject: World's Heaviest Head
PostPosted: Sat Nov 25, 2017 6:14 pm
Just finished putting together the head for my Lancer. I am using the 75-77 head, 3698447, and it must weigh a ton! Next time I build one of these heads I am going to cut the cast iron out from the push rod side and see how much I can save.
 Post subject: Re: Worlds Heavest Head
PostPosted: Sun Nov 26, 2017 7:20 am
I think those heads are about 10 lbs heavier than the earlier heads. I would be curious to see how much you could lighten the head, but I don't think it would be near 10 lbs.
I am curious, what is the lightest factory slant head and what is the lightest iron head anyone has built?
PostPosted: Sun Nov 26, 2017 11:43 am
LOL... yeah compared to the 1974 and earlier drool tube head or the 1981-1987 hydro motor head, it's a monster... but not as heavy as the non-exhaust air port injection head that has the lack of air ports and passages...
It will take a while to carve out that section, I've run a burr in there to help with oiling and relieve the pushrod holes a bit when running 3/8" pushrods...there's a lot of meat.
I don't think I've ever figured out what's worse in weight and lower back soreness... laying an early to mid-60's forged crank or a 1975-1980 head....
:roll:
PostPosted: Sun Nov 26, 2017 3:43 pm
I am getting ready to send a 220635-2 head off my 1962 to the machine shop for work. Bare and clean
66/67lbs. When I get it together again I will weight it to get a total.
PostPosted: Sun Nov 26, 2017 3:52 pm
Car Model: 63 Dart 81 D150
The in line 6 head of a 60's to 80's Jag, now there is a heavy beast.
PostPosted: Sun Nov 26, 2017 5:32 pm
I will weigh it tomorrow, I am guessing 85 with valves.
It will take a while to get that much cast iron off for sure.
I wonder if this head would be good for a turbo and for gasket sealing?
PostPosted: Tue Nov 28, 2017 12:17 pm
Car Model: 1966 2D Dart
Nice. I was thinking I am coming old and weak. 35 years ago it was easy to install mid-60's head alone. Now with small plug head I need a crane or assistant. But it was only because they have add material for late heads. :D
PostPosted: Fri Dec 15, 2017 3:00 pm
Just got my head put back together after the machine work. Complete from plugs to stat housing. 74/75 lbs.
PostPosted: Sat Dec 16, 2017 11:15 am
DI:
That's the one riding atop my engine, yup, heavy, heavy, heavy.
PostPosted: Fri Dec 29, 2017 5:40 pm
Put it on the scale, 80.8 with valves and springs. After .100 cut. No t-stat or rockers. Dang.
PostPosted: Fri Dec 29, 2017 7:48 pm
Must be a record! Lots of metal to hog out to make flow... Mike J said he liked those late 70s heads best for that reason - more material to remove.
PostPosted: Fri Dec 29, 2017 7:53 pm
Yeah, it's not a weight saver, and the pushrod holes are a bit small... but the "Fatpak" head I hogged the crap out of to port match that intake...
I hadn't hit water and i know a drool tube head wouldn't take that kind of abuse....
Users browsing this forum: Bing [Bot] and 16 guests
