It is currently Fri Jan 02, 2026 4:37 pm
 Post subject: Re: Slant 6 ID
PostPosted: Sat Feb 10, 2018 12:51 am
The 1971 225 is rated at 145 gross HP and 8.4 to 1 compression.
Is this accurate or over rated?
See here and here.
PostPosted: Sat Feb 10, 2018 3:54 am
Car Model: 1955 Dodge Truck
See here and here.
Thanx Dan wonder what my Chrysler 265 IND L head really puts out.
Its rated 120 hp at 3600 RPM and 228 ft lbs of torque at 1600 RPM.
I think my 265 will.have mote torque than a slant 6 but a slant can be built for more hp.
PostPosted: Sat Feb 10, 2018 7:40 pm
Now here is a decision i might end making.
Do I swap in the slant 6 into my 1955 Fargo truck with an A833 overdrive.
Or go with another flathead i havev a 265 industrial engine.
It needs rebuilding.
Decisions decisions.
PostPosted: Sat Feb 10, 2018 7:43 pm
Hi Dan i am about to buy a bell for the A833 for the slant 6.
I also.need a flywheel are the flywheels all the same size and tooth count same too?
The bell is from a truck.
