It is currently Sun Jun 21, 2026 2:40 am
 Post subject: New Valve Cover
PostPosted: Thu May 06, 2004 10:59 pm
I am still looking for anyone in the LA area who would be willing to drop by PML and let them look at a slant six and how it fits in the engine compartment.
They would like to move the side walls out to the edge of the gasket flange. I do not think this would cause any problems but I am not sure about the earlier cars. the side walls would be much thicker so they would be more rigid with better clamping force.
this is what this would look like go down a few to 7872-5(finned cad 500)
http://www.yourcovers.com/newvalve.htm
Are there any clearance issues with the older cars?
Steve
PostPosted: Fri May 07, 2004 10:50 pm
Steve,
Haven't found anybody yet either, still working on it. Come on Angelenos, it won't take much time and a new product is always welcome.
Took a look at the Caddy reference piece and like what I see. Do you know whether they're looking at angling the top of the box parallel to the deck or to the ground? As yet I've had no response to my own inquiries, I think they'd prefer to deal with just one person. Makes sense to me.
Don't give up, Dick
PostPosted: Sat May 08, 2004 6:31 am
I have a '66 Valiant, and there are no clearance problems that I can see. I can send you pics of the engine compartment if you need them. :shock:
PostPosted: Sat May 08, 2004 2:27 pm
Thanks Dennis
I would appreciate a few photos of your 66. My 69 is in parts and pieces so pictures won't do any good. We may need some other photos from other cars if anyone else has some good clear ones. It will be tough do design a new product from long if nobody in LA steps up.
I would want the top of the cover be in the same plane as stock.
and everyone remeber to let PML know what you think about a new valve cover and what you want to see in it. The more e-mails and phone calls they get the better our chances.
Brent Lottman (brent@pmli.com)
PML, Inc.
(310) 671-4345
Thanks
Steve
PostPosted: Sat May 08, 2004 2:29 pm
Sorry, I forgot to include my e-mail
snmhall@bctonline.com
 Post subject: Step Up Please!!
PostPosted: Sat May 08, 2004 3:31 pm
I would be glad to stop by but the 3000 mile drive from Pa. with 4.30 gears is just a bit much!! I'll be glad to get you some photos of our 72 swinger engine compartment if they will help?? Just let me know.
The truth of the matter is, with over a thousand members to this board, if no one steps up out in LA., maybe we don't deserve a new valve cover?? If someone is willing to design us a new product, this should be the least we can do to help them. Just my 2 cents worth.
Rick
PostPosted: Sat May 08, 2004 11:06 pm
Thanks
if you could send me a couple of close ups of the valve cover area that would help. It looks like I will have to gather up what pictures I can and send them to PML in place of seeing a couple of cars in person.
Thanks
Steve
PostPosted: Mon May 10, 2004 9:50 pm
Brent at PML would like to know if the outter most turned down lip on the gasket flange is needed for proper sealing(gasket retention or just rigidity) any input would be helpful. the new cover would be a thick wall AL and have a heavy flange for sealing.
thanks
Steve
The fins and script on the 7872-5 are milled down into the surface of the part instead of being raised features. I know with pictures on the computer it can be a little hard to tell.
As far as moving the walls on the slant 6 valve cover outward all the way to be flush with the flange, I'm just trying to understand what the design constraints are for a new cover. The finished design may have an external flange like the stock cover (certainly would if there is something non flexible running right up against the side of the valve cover) or it might be similar to our 7872 valve covers. Not being familiar with the ins and outs of the slant 6 engine and it's plumbing/wiring etc, I'm relying on you to give us the information needed.
Did you have any information about the need for a turned down lip on the outer edge of the gasket flange? Is this something you guys want/need for gasket retention?
Regards,
Brent Lottman
PML Inc.
310-671-4345
PostPosted: Mon May 10, 2004 10:14 pm
Where is PML located? I'm in Los Angeles and could stop by there on one of my off days providing that I'm not busy. If I'm correct I have three differrent valve covers that I can show them. I have 2 68s, a 75, and a 78. I also have a chrome valve cover that I took off of a 63 truck that I found in the JY. I'll have to double check to see if its stock or after market.
Dart68
PostPosted: Mon May 10, 2004 10:19 pm
The lip is to help reinforce the sheet metal valve cover and keep the gasket from puckering out.
I live in Salem, and have a couple of covers and heads that are 'just lying around' until I get them cleaned up for the 'next phase'. You can PM me and we can set up a free moment so you can get some measurements and take all the pics you want.
PostPosted: Tue May 11, 2004 2:48 pm
They have some neet covers! And nice thick flanges I would take one of them!
Frank
PostPosted: Tue May 11, 2004 9:01 pm
thanks dart68 that would be great, they really want to see an engine compartment to see how everything fits. here is the contact information and they would like a day notice if possible.
PML, Inc.
201 West Beach Ave
Inglewood, CA
(310) 671-4345
Thanks dusteridiot for the offer but I already sent them a factory cover to look at and at this point they just want to know if a wide flat AL flange would seal or do they need to machine a lip like the factory cover has to keep the gaskets from squirting out. this extra step would cost a little more money.
Also if anybody has real tight clearance issues around the valve cover and some other part on some models that might make a difference as to how they build the new one
thanks
Steve
PostPosted: Tue May 11, 2004 10:35 pm
As for clearance issues, the 60-62 Valiants & Lancers with a "tall block" 225 will have tight clearance to the firewall mounted heater box.
About the recess / outer flange, yes, that would be good to have, along with the little cut-outs that accept the tabs of the valve cover gasket.
Without these features, the valve cover gasket become a pain to install, you have to glue it to the cover to be sure it does not slip off the sealing flange. The extra cost is worth it in saved installation trouble, besides, if you are going to make a nice "high-end" product like this, don't cut corners, make it a "trick" part that is as easy to use as the factory cover.
PostPosted: Wed May 12, 2004 6:20 pm
Thanks Doc
That's what I wanted to know. I will let PML know and see how things go.
Thanks
Steve
PostPosted: Fri May 14, 2004 5:13 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
I'll be out of town till late June after that let me know. I live up in Castaic. 45 min from LA
Mike
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
