It is currently Tue May 12, 2026 5:12 pm
Post new topic  Reply to topic  [ 705 posts ]  Go to page Previous 142 43 44 45 46 47 Next
 Post subject: Re: GodsRods Duster II
PostPosted: Thu Sep 27, 2018 7:41 am
I didn't have nuthin', so I asked Dennis about his junk. He told me Professor Lou had dibs on his, so I went to Amazon & got a Nitrous Express Mainline kit. I'm still fiddlin' with gittin' it all set up, kinda like everything else I do... :roll: :lol:
I've got a couple healthy 904 converters, but they're bolted to the Duster and Challenger engines. One of 'em I know works... The other one I'm still hopin' to find out... See last sentence above... :lol:
PostPosted: Thu Sep 27, 2018 8:30 am
Hitting a standard converter with nitrous will raise the stall on it a couple hundred or so...... :?
PostPosted: Sat Sep 29, 2018 4:57 pm
I got the fuel lines for the nitrous plumbed and tested today. Other than a needle/seat issue that was easily cleared everything went well. I decided to go simple/cheap and just run the one regulator after all.
The nifty steering wheel nitrous button broke, so I need to wire another button and test that side of things. Then I’ll be ready for Mason Dixon. :D
PostPosted: Sat Sep 29, 2018 7:17 pm
Howard gave me a set of solid motor mounts for the Duster, so I put them in tonight as well. Thanks again Howard!
PostPosted: Sat Sep 29, 2018 8:29 pm
Does the horn still work? Unplug the horn from the relay and hook the kit to it. It works well, trust me. :mrgreen:
PostPosted: Sat Sep 29, 2018 8:38 pm
It has an aftermarket steering wheel and the horn button is long gone.. :(
I’m putting a button down by the shifter for now.
For these couple 1/8 mile record passes I only plan to hit the button after I shift to second to the finish line. Then I'll let go of the button and sloooowly ease out of the throttle... :wink:
Typically on an 1/8 mile pass I hit 6,000-6,300 RPM at the finish... Will adding nitrous change that significantly? If so, I will have to figure out a different finish line strategy... :?
PostPosted: Tue Oct 02, 2018 4:02 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Sure you don't need another one :lol: ??
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Tue Oct 02, 2018 6:07 pm
Yes, it will wind up higher. Just wait until 7000 to shift anyway. :mrgreen:
PostPosted: Tue Oct 02, 2018 7:01 pm
Can you ever have too many? :lol:
PostPosted: Tue Oct 02, 2018 7:05 pm
I HAVE been hangin’ out with Howard some lately, but that part ain’t rubbed off yet. :shock:
I did get the Go Go Juice button all wired up & makin’ clickin’ noises tonight. :D
PostPosted: Tue Oct 02, 2018 8:30 pm
How's the song go? Click, click, BOOM! :mrgreen:
PostPosted: Wed Oct 03, 2018 4:09 am
Noooooooo!!! :shock: :shock:
PostPosted: Fri Oct 05, 2018 5:20 am
We are loaded up and ready to head to Mason-Dixon!
Angie will be entering the race for Rookie of the Year! :D
With the added weight of the nitrous system the Duster is still in B class, so I’ll be trying for the B/Nitrous record in my attempt to catch Ryan for the Championship.
PostPosted: Fri Oct 05, 2018 6:24 am
Good luck to the both of ya! :D
PostPosted: Fri Oct 05, 2018 3:37 pm
Thanks! Just pulled into the motel in Hagerstown.
