It is currently Sat Jun 13, 2026 6:04 pm
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 178 79 80 81 82128 Next
PostPosted: Thu Apr 04, 2019 5:43 pm
Engine is in, all the braided lines are run, the remote oil filter set up is in.Transmission is in and all the lines, shifter cables...etc are hooked up, drive shaft is in. New header wrap arrived for the Clifford big tube race headers, and they have been painted with a couple coats of VHT silver. Pics to follow! 4 weeks!!!
PostPosted: Sun Apr 07, 2019 6:13 pm
Redline manifold had some pretty bad core shift up and down. I spent a couple hours straightening things up.Middle cylinders were low and the outside ones were high. It ended up with the ports 1.400" X 1.250" This size is just a little larger than my Clifford I was running.
Here is what I started with!
Here is what I ended up with.
This little tool is great when porting. You can run it back the port on the intake and tell where you need to work on it. Digital read out and spring loaded arms makes it easy to see and easy to get each port the same. Great $15 purchase.
PostPosted: Sun Apr 07, 2019 6:27 pm
Car Model: 1975 Dodge D100
Nice work!
PostPosted: Mon Apr 08, 2019 5:37 pm
That looks better.
Good thing greta purchases nice dro inside calipers!
PostPosted: Tue Apr 09, 2019 8:53 am
yes, I had trouble with the smaller 9/16 head bolts coming loose but since I had the bolt size increased to the 3/4 head I have no issues.
PostPosted: Tue Apr 09, 2019 10:19 am
I've come to expect this kind of impressive work in your thread. Carry on.
PostPosted: Tue Apr 09, 2019 11:29 am
Niiiiiicceee!!!!
PostPosted: Mon Apr 15, 2019 4:12 pm
Rick have you run your pump yet? wondering what your oil pressure is at idle? fired mine today had 70psi at 1200rpm, still waiting for my rad so couldn`t run it long so don`t know what it will be when the oil see some temperature .
PostPosted: Mon Apr 15, 2019 4:24 pm
That seems about right terry. Should drop to 50-60 hot.
PostPosted: Mon Apr 15, 2019 5:17 pm
No I got all my fluids today, and I am waiting on a couple fittings for the fuel system. Hope to start it this weekend. I am really running behind. I am usually ready to race by March 1!
PostPosted: Mon Apr 15, 2019 5:35 pm
thanks Greg. ya! I know the feeling, close friend is tig welding the lower rad hose pipe to clear the pump.
PostPosted: Sat Apr 27, 2019 10:28 am
Ok, Race car has been fired up. All the oil and water stayed inside and no oil leaks at any of the new hose / fittings that I installed. Had a problem with the new fuel system. Brand new Professional products canister type fuel filter was put into my hard lines at the rear and it leaked like a sieve! Removed the top bolt and looked at everything and after 2 more atempts I gave up. Removed it from the hard lines and took a closer look at where the leak was. It was coming out right at the top bolt that holds it together. They supply a copper washer for under this bolt to make the seal. Only problem is the bolt does not have enough of a flat surface are under it to seal to the canister. Also the spot on the canister where it seal is really rough and has extra thick paint there, some of which chip off and allows and even more uneven place for the washer to seal. All in all very frustrating and I would never buy another one like it. Although I can probably make this one work with some work and a new bolt and washer, I just cut off the hard line and install a inline metal filter for now. Here is a picture.
Please see the transmission section though, because "Houston, we have a problem!"
PostPosted: Sat Apr 27, 2019 1:11 pm
Sooo pretty. Hope the trans comes together quick - fingers crossed!
PostPosted: Mon Apr 29, 2019 8:43 am
Did you get your transmission figured out?!?!?!
If not i bet your company has some sick time for you tucked away in the attic with the mower parts.
PostPosted: Mon Apr 29, 2019 9:56 am
See here. Not yet
http://www.slantsix.org/forum/viewtopic ... 0&start=15
