It is currently Mon Nov 16, 2026 5:56 am
 Post subject: Oil priming
PostPosted: Sat May 11, 2019 9:34 am
First, a sexy pic of the Smith Bros 3/8" pushrods, .100 shorter than stock....
As I finish up the 225 rebuild, I primed the engine before putting the valve cover on for the final time. I like to do this to ensure the rocker shafts are getting oil, and of course to fill all the oil passages and filter with oil. I'll prime it again before I start it.
The pump is a generic small block (318) pump with an NPT tapped 'block off' plate on the outlet to connect to a hose. If you don't have a port on the oil galley at this location, there is also a port at the oil pump itself under the filter. The inlet side of the pump is just connected to a hose and stuck in the oil jug.
After about 10 seconds of spinning, there was a very nice flow of oil along the rocker shaft, you could see each rocker getting oil and the oil making its way out to the valve tip and rocker screw.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 5 guests
