It is currently Wed Sep 30, 2026 3:36 pm
PostPosted: Fri Jul 19, 2019 7:46 pm
Car Model: 1964 Valiant
Will the v8 radiator, shroud, and hoses from a Ramcharger work with a slant six in a 'D150. Both trucks are 1986.
PostPosted: Fri Jul 19, 2019 8:11 pm
Yes! Provided you use a flexible upper radiator hose since the V-8 radiator puts the upper hose on the opposite side of the radiator from the slant six.
PostPosted: Fri Jul 19, 2019 11:43 pm
You're correct Reed. I just noticed that I first registered to this forum a day before you back in 2002.
PostPosted: Sat Jul 20, 2019 9:55 am
:mrgreen:
Time flies.
PostPosted: Sun Jul 21, 2019 7:58 am
I put a v8 radiator in my '84 W150. I used the v8 upper hose but had to trim. The v8 rad has a larger diameter lower hose so I had to use an adapter. The v8 shroud didn't fit. I had to elongate the bolt holes in the slant shroud to make it fit.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Wed Jul 31, 2019 9:58 am
I have a 4 core brass radiator from a D-350 tow truck equipped with a 360 in front of my slant and used the stock slant shroud. Like already mentioned, just use a flex hose. Keeps it nice and cool even in 105 degree weather.
Users browsing this forum: DuckDuckGo [Bot] and 27 guests
