It is currently Mon Jun 22, 2026 3:45 am
PostPosted: Sun Sep 22, 2019 8:31 am
Car Model: 1980 Chrysler lebaron 3.7l 225ci
I just want something looks cool and works effective as the factory rocker arm assembly and any ideas on a 400 hp set up???
PostPosted: Sun Sep 22, 2019 9:09 am
The factory rockers are surprisingly good and the aftermarket ones that have been tried have often had oiling or other issues. Spend money elsewhere.
400hp you say?
PostPosted: Sun Sep 22, 2019 11:12 am
Tell us more of what you are really looking to do? Rocker arms look cool but only when you are broke down and have the valve cover off to fix something! :D :D
400 HP is not in sight without a power adder... Turbo, blower, or nitrous
PostPosted: Sun Sep 22, 2019 5:13 pm
In all seriousness, 400 streetable horsepower will take a turbo. Stock rockers would be fine, as long ss they are in good shape.
PostPosted: Sun Sep 22, 2019 6:38 pm
Site Admin
If you want to go roller rockers, T&D in Nevada would be my recommendation. Been a while since I bought a set. I think they're around $750 on your rocker shaft. That would be mechanical only. Not much reason to go with Rollers, as the engine won't spin fast enough for it to make much/any difference. That said, I have a set of RAS which I don't recommend, and a set of T&D's. They look really spiffy when you have the cover off. Adjusting the valves becomes a heck of a chore, as the adjusters are more difficult to deal with. You can order the ratio you want from either. Anything larger than 1.5 will result in some screwy valve geometry. Any of them tend to require custom push-rods. I use Smith Brothers. The shaft tower height will be wrong, but in most cases, not enough to cause problems.
For 400 crank HP net, I'd recommend an LS swap. :lol:
400 HP from a slant puts you in hero territory. Possible? Yes, for a price. There are several strip only cars that live brief lives up there. Very few, if any, street cars. You must have a power adder to get close to those kinds of numbers.
HP=Torque*RPM/5252 HP is just a number. The only use for which would be bragging rights. Dialing quicker than a BB-wedge car and reeling him in at the stripe? Priceless! :D
What are you trying to do?
CJ
PostPosted: Tue Oct 08, 2019 10:27 pm
For sure I was going to turbo it but idk if efi or carb will get me in that range? A stronger cam,Cheetah turbo action transmission shift kit and a bigger exhaust. Maybe a super 40,but for the dual turbo set up. I want it under the vehicle to keep the sleeper look.
PostPosted: Tue Oct 08, 2019 10:28 pm
How much boost can the slant handle
PostPosted: Wed Oct 09, 2019 9:19 am
Done poorly or well? 8)
A poorly done 5 psi setup won't last long. A well done 15 psi setup will last much longer. If you've never built a turbo engine you should expect to make mistakes and get good at changing head gaskets and pistons.
PostPosted: Wed Oct 09, 2019 9:56 am
I think its easy to build the engine for boost or na. The engine management is what needs to be taken into consideration.
Go megasquirt /motec / haltech etc. for and fueling and timing then you'll be okay.
PostPosted: Wed Oct 09, 2019 4:32 pm
http://www.rockerarms.com/pdf/slant6flyer.pdf
These Look Really Cool!
1964 Dart GT
PostPosted: Wed Oct 09, 2019 7:20 pm
Oil spray bar optional....
PostPosted: Wed Oct 09, 2019 7:41 pm
I have a set of those. Look cool, didn't make much difference.
PostPosted: Thu Oct 10, 2019 3:22 am
Spray bar needed for street use.
Ask how I know?....
My set had a soft shaft that would squash when torqued. Used less torque and loctite.
