It is currently Sun May 24, 2026 6:28 am
PostPosted: Sat Nov 30, 2019 1:47 pm
Howdy all. I'm looking to make my leaning tower of power the meanest sounding on the street. I'm willing to buy lifters, pushrods and rocker shaft/arms too. I just want this thing to sound intimidating! Any advice or suggestions would be greatly appreciated!
Thanks! :mrgreen:
If You get an aggressive cam, the 1st thing on Your shopping list should be a loose converter,...not cheap but get one(call the co.)
PostPosted: Sun Dec 01, 2019 3:15 pm
SL6 Racer
Here is my 2 cents........... call Ken at Oregon Cam...........
He does this for a living..........
PostPosted: Mon Dec 02, 2019 10:40 am
Here is the OCG 34 grind as Ceej stated.
https://www.youtube.com/watch?v=P4Itrk02xVY
Sounds nasty at idle and makes not a lot of torque. The head will be coming off so I can get the compression up where it needs to be. Since this is a stock stroke engine I should be able to make use of the upper end once compression is sorted.
I'm also very limited due to my PB A904 since no one really makes converters for them, and I'd be looking for about a 2800 stall.
~THOR~
PostPosted: Mon Dec 02, 2019 11:13 am
~THOR~
Sounds mean. I like it!
PostPosted: Mon Dec 02, 2019 12:25 pm
SL6 Racer
Thor
Call Superior Torque Converter 503 238 0448 They are in Clackamas
Just had them do another converter for the 36 Valiant.....
Had much better luck with them then A-1 in Vancouver and they were much cheaper.
PostPosted: Mon Dec 02, 2019 12:31 pm
All the places I've chatted with so far won't/can't do the small nose converter; not sure why.
I'll check on the place in Clackamas; if they can do the early small nose converter that would be a big help.
~THOR~
PostPosted: Mon Dec 02, 2019 2:49 pm
Call Andre at Edge Racing Converters https://www.edgeracingconverters.com/
He has made them in the past, and even made me a couple of small pilot, large spline converters.
