It is currently Sat Nov 14, 2026 1:08 am
Post new topic  Reply to topic  [ 46 posts ]  Go to page Previous 1 2 3 4 Next
 Post subject: Re: The new hughes cams!
PostPosted: Tue Dec 17, 2019 3:22 am
I can't see the files??
PostPosted: Tue Dec 17, 2019 4:58 am
I am not sure if ss.org allows a .pdf attachment? or it may be too large.
Maybe just share a direct link or post it to google docs or something.
Thank you,
PostPosted: Tue Dec 17, 2019 6:53 pm
Car Model: 69 Valiant
I've tried several times to get them to upload. Anyone know the trick to this? They're PDF files.
PostPosted: Wed Dec 18, 2019 3:56 am
I have only ever loaded Jpeg files here. Greg may be righjt ahe Pdf's
PostPosted: Wed Dec 18, 2019 8:38 am
I'd assume the forum will only let you update image files. You could do a screen capture of the PDF reader while you have the files open, but depending on how many pages there are and how far you have to zoom in to make things readable, it could be tedious.
Escape Velocity Racing
PostPosted: Wed Dec 18, 2019 11:51 am
Post it to google docs or some other service and post a link or send it to me and I can do it for ya.
Pm me for email.
PostPosted: Wed Dec 18, 2019 1:42 pm
I shared the link to Google docs on my original post. Let me know if it doesn't work.
PostPosted: Wed Dec 18, 2019 5:29 pm
Yes those work!
PostPosted: Wed Dec 18, 2019 5:47 pm
Well, I don't know if they are any good or not, but they definitely have the tightest valve lashes I have ever seen advertised ??
PostPosted: Sat Dec 28, 2019 7:04 am
Car Model: Plymouth fury 61
It's apperently because of the high lift lift like someone said here.
I'm just wondering if they are a good upgrade for a cruiser in a heavy '61
PostPosted: Sat Dec 28, 2019 9:23 am
That's not a good assumption to make. It's a tight-lash solid is all we know. It's not a Hughes innovation here. Probably Engle like their older cams.
It would be an experiment. Frankly, the valve spring seat and open pressures are quite high. If they really do need that much spring force to keep the valve train in check then cam, lifter and valve train life is not likely to be long nor are they likely to be low maintenance. For anything street driven I'd chose a cam with a lower rate of lift and lower spring pressure requirements.
PostPosted: Sat Dec 28, 2019 11:23 am
I would worry about durability, as Josh and others have said. Please post what kind of performance and running/driving characteristics you desire, and a proposed budget. Then we can help you pick a cam.
PostPosted: Mon Dec 30, 2019 12:28 am
Awesome!
I've got a 61 fury so it's pretty heavy
Double holley 1920
Hei ignition
(shortie headers with 6-8ft secondary pipes) in the making
Stock engine
3.32 rear end (might in the future swap for a 2.92)
Planning is just a cruiser i don't get over 3500 rpm and don't plan going faster as that. Just want torque and mpg..In the lower rpm!
PostPosted: Mon Dec 30, 2019 3:06 am
OK, that is very helpful. I assume you have a stock automatic trans. Sounds like a nice cruiser. You will want just a bump above a stock cam. Unless you do head porting, you will not gain a ton of power/torque from just the cam, but you will gain some above a stock cam.
I believe Ken at Oregon Cams has specs for a "reverse dual pattern" cam for stock head and auto trans. I am not able to find those specs right now on this site. Can someone here maybe help find the link to that? I can look more later too.
More to come...
PostPosted: Mon Jan 20, 2020 12:07 pm
More to come...
Perhaps something like the rv10 is more what i need.. Just a low rpm high torque cruiser.
Going to Rebuild the head and raise the compression.. And do minor head work and add an electric fan.. Just stuff to increase the torque and mpg!
Hope it's possible stuff like this is always a pain if you're from Europe
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 10 guests
