It is currently Sun Nov 15, 2026 3:29 pm
 Post subject: Header Collector Gaskets
PostPosted: Wed Mar 04, 2020 5:22 pm
Rock Auto has a sale - close out going on the Walker 31369 gaskets.
These fit the collector flange on Hooker Long Tube Headers.
1.81 each
https://www.rockauto.com/en/partsearch/?partnum=31369
PostPosted: Wed Mar 04, 2020 6:37 pm
Thank you for sharing that John. :)
PostPosted: Thu Mar 05, 2020 9:11 am
Just ordered enough to last me until I die. :mrgreen:
Thanks again for posting John! :D
PostPosted: Thu Mar 05, 2020 5:22 pm
you are welcome,, yea, I have five sets,,,
PostPosted: Thu Mar 05, 2020 7:52 pm
Me too! :mrgreen:
PostPosted: Fri Mar 06, 2020 6:12 am
Hi John,
Do they really have the stainless fire ring, like in your pic? The Rockauto pic has no fire ring, but maybe it is just a stock pic.
Thanks much,
PostPosted: Fri Mar 06, 2020 8:07 am
The pile of gaskets on the left in the photo that I posted are the gaskets from RA. The packaging says ‘Replace Walker...’
The single gasket on the right is a Walker gasket.
Both sets have a stainless ring at the center.
You are correct that the photo in the listing does not show a ring, but the ring is present on the gaskets that I got.
PostPosted: Fri Mar 06, 2020 8:37 am
Ordered. I'm pretty sure the Spitfire headers on my V8 Dart use the same ones.
PostPosted: Fri Mar 06, 2020 10:50 am
Great! I ordered some.
PostPosted: Thu Mar 12, 2020 5:09 pm
Hello, Don't yell at me a lot,,,
these Rock Auto collector gaskets have an undersized bolt hole diameter that splays the collector mounting bolts and causes interference when bolting the collector to a collector extension. At least that is what I found. It is easily correctable. The RA collector gaskets have slightly under sisized ( and out of position ) mounting holes. See the overlay photo.
Use a drill bit to bring the RA gasket mounting holes to the diameter of the Walker gasket mounting holes and all is fine.
Maybe that is why the RA collector gaskets are discounted. I really don't know, but they have the stainless ID gasket and a very substantial exterior gasket, with the mounting holes small and off location.
File comment: collector gasket overlay, Walker and RA gasket
File comment: Bit used to open the collector gasket bolt holes
PostPosted: Thu Mar 12, 2020 5:18 pm
.438 vs .368 is the bolt hole diameter.
.070 undersized and not on the same nominal, see how the bolt hole centers do not align.
that will cause difficulty went assembling the header-collector gasket-collector extension.
however it is easily resolved by opening the gasket bolt hole diameter.
2.47 vs 2.48 is the center exhaust diameter
.01 difference, very inconsequential.
open the mounting bolt holes and life will be great.
PostPosted: Thu Mar 12, 2020 6:13 pm
Mine just arrived. I might find something they will fit on. :wink:
PostPosted: Thu Mar 12, 2020 11:57 pm
The bolt spread looks to be good for my Cliffords. They'll be fine. :D
PostPosted: Fri Mar 13, 2020 3:05 am
Thanks for the head(er)s up. No worries. I have a little pile now too.
Users browsing this forum: Bing [Bot] and 9 guests
