It is currently Sun Oct 11, 2026 6:27 pm
 Post subject: Help!!!!
PostPosted: Fri Jun 18, 2004 4:48 pm
my 68 valiant with 225 is running like crap. it runs fine at idle, but as soon as i put a load on it, it misses very badly. i rebuilt the carb and threw cap, rotor wires and plugs on it and timed it the best i could without a light. still misses on accel. could this be a points problem? any ideas would be greatly appreciated! plz help!!!
thanks , rhyno 6
PostPosted: Fri Jun 18, 2004 6:42 pm
Replace points/condensor. Probably wouldn't hurt to change plugs, too. Motor will run fine after you do this.
D/W
If it ain't broke, fix it!
PostPosted: Fri Jun 18, 2004 6:56 pm
It could be fuel related also-- check condition of fuel filter,fuel pump,and accel.pump in the carb.Sounds like a fuel starvation problem.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Fri Jun 18, 2004 7:50 pm
Car Model: 1967 Dodge Dart GT
my 67 sat for 9 years before we got it and acted similar, previous owner had left it full of gas for all that time the sending unit was clogged, so if it sat and the other stuff doesnt work, that would be my next step, good luck!
PostPosted: Fri Jun 18, 2004 9:46 pm
I stand by my ignition assessment, from the description, sounds to me like the condenser is going out or the points are toast - but really hard to tell fer sure without the car in front of us, now isn't it? Good suggestions, all...
Rhyno, please go buy (or borrow?) a cheap timing light. There's no excuse for not using one - Some really screwy timing could be contributing to the problem, too.
D/W
PostPosted: Sat Jun 19, 2004 4:41 am
I second the timing light. my car will idle fine anywhere from 15*after to 10* before top dead center.
PostPosted: Sat Jun 19, 2004 5:20 am
we went through the ignition stuff first, and it still did it, so thats why i said if ignition doesnt fix it that could be the problem, mine idled great, sounded perfect, "we finally got it running! lets go for a drive!" got up to 50ish and started to sputter...carb rebuilt to....
try the ignition stuff first, if it doesnt fix it it will still help it run better/better mileage
good luck
PostPosted: Sat Jun 19, 2004 2:20 pm
it was the points guys! thanks for the help
PostPosted: Sat Jun 19, 2004 3:18 pm
D/W
*bows"
:lol:
PostPosted: Sat Jun 19, 2004 5:09 pm
Dennis gets the cigar!!!! 8) 8) 8)
PostPosted: Sat Jun 19, 2004 6:59 pm
*applauds*
:D
PostPosted: Sat Jun 19, 2004 9:55 pm
Get rid of the points and get a Pertronix electronic set up or the factory electronic ignition. Best thing you will ever do to your car. I hated pulling the distributer out every time I had to change points, and I have a B body with more room!
Oh yeah, all hail Dennis! :mrgreen: :wink:
PostPosted: Sun Jun 20, 2004 12:13 am
Or better yet, if you want even more of a challenging project, get rid of the distributor all together and set up a crank trigger/dis.
PostPosted: Mon Jun 21, 2004 7:16 am
...as it should be! 8) :D
 Post subject: six
PostPosted: Tue Jun 22, 2004 9:18 pm
my buddy from work told me to go to a junkyard and find a 80's jeep, and pull the maifolds and ignition off and put it on my slant 6. what u guys think of that?
Users browsing this forum: No registered users and 24 guests
