It is currently Mon Nov 16, 2026 12:33 am
 Post subject: 1979 Super 6 Carb
PostPosted: Sat May 02, 2020 2:36 pm
I have 2 '79 Super 6 carbs. I'm trying to keep the original 27k mile carb on this car. I've taken it apart now I'm lost in the assembly of the accelerator pump and metering rods. Even watching the video I'm lost. Looking at the other '79 carb off an aspen I'm still unsure. Am I the only one thats been in this position.
 Post subject: Re: 1979 Super 6 Carb
PostPosted: Sat May 02, 2020 4:48 pm
PostPosted: Sat May 02, 2020 5:00 pm
look like this one,that metal arm for vent goes on above plastic acc pump arm. Is that the problem?
PostPosted: Sat May 02, 2020 5:41 pm
PostPosted: Sat May 02, 2020 5:42 pm
PostPosted: Sat May 02, 2020 5:44 pm
This 1st pic is the one off my '79 Aspen . Its like your pic. However, the 2nd pic is the carb off my 27k mile car. The top is not attached to the body of the carb so the accelerator pump is not pushed up. Is that my problem???
PostPosted: Sat May 02, 2020 5:46 pm
The pictures are reversed.
PostPosted: Sat May 02, 2020 5:48 pm
Get the plastic arms in place then slide the shaft in.
PostPosted: Sat May 02, 2020 6:11 pm
Quick answer yes. The book says to place pump drive spring on plunger shaft and then insert shaft into air horn. Compress spring far enough to insert S link.
PostPosted: Sat May 02, 2020 6:27 pm
Thanks Mat, I'll see if I can fix my screw ups.
PostPosted: Sat May 02, 2020 7:22 pm
Metering rod adjustment http://www.slantsix.org/forum/viewtopic ... ering+rods
PostPosted: Sun May 03, 2020 7:04 am
The bowl vent should be tested . At hot curb idle should be open. At just off idle should close and seal, if does not seal atmospheric pressure will enter bowl an cause over rich mixture. About 7 minutes into this film. http://www.imperialclub.com/Repair/Lit/Films/303/
PostPosted: Sun May 03, 2020 8:07 am
I wish I hadn't opened this carb. It sat for 5 years with fuel and it needed to be cleaned. It cleaned up really well being a 27k mile carb. No one really builds carbs anymore.
PostPosted: Sun May 03, 2020 10:05 am
Clean your idle tubes.
PostPosted: Mon May 04, 2020 11:31 am
Car Model: Dodge D100 Utiline
This vid has it all.
https://www.youtube.com/watch?v=nBtqTbG ... ex=2&t=11s
