It is currently Mon Nov 16, 2026 1:41 am
PostPosted: Thu May 07, 2020 12:29 pm
So the '79 /6 Super 6 are to be adjusted like the older /6's??? Am I correct in this assumption. .010 I and .020 E while running.
PostPosted: Thu May 07, 2020 1:03 pm
Yep. If the rocker arms have adjusters, then you need to do the lash. They went to hydraulic (non-adjustable) in 1981. The only twist would be if someone swapped your motor over to a hydraulic cam and rocker assembly, but I doubt it.
PostPosted: Thu May 07, 2020 1:30 pm
Thanks for the quick response. 27k original miles. It has adjusters. I have to rig up some hose and wire pull ups. Its not like adjusting valves in my '61 Dodge Seneca with all the room in the world.
PostPosted: Sat May 09, 2020 5:42 am
On my 79 Volare Wagon, I adjusted them hot, .010 intake, .020 exhaust. I adjusted them after the engine warmed up but not while it was running. That worked well for me.
PostPosted: Sat May 09, 2020 9:47 am
I do mine by the manual. Running with SNOT FLYING. LOL
PostPosted: Sun May 10, 2020 8:59 pm
I have only done mile once at about 22,000 miles. Warm engine idling away, went OK just a little oil flying about.
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
