It is currently Mon Nov 16, 2026 5:12 pm
 Post subject: Distributor Shield
PostPosted: Thu May 28, 2020 7:39 pm
Car Model: 1966 Plymouth Valiant
Any problems or down side to removing the shield by the dist and oil filter?
 Post subject: Re: Distributor Shield
PostPosted: Thu May 28, 2020 8:34 pm
It's there for a real good reason, to keep water and mud and other gunk from hitting the distributor. It weighs almost nothing. Why would you remove it?
PostPosted: Thu May 28, 2020 9:57 pm
Because the crack between the bolt holes. If you remove it, drive slow thru deep puddles, or you will soak the distributor.
 Post subject: D
PostPosted: Fri May 29, 2020 6:10 am
D
PostPosted: Fri May 29, 2020 8:11 am
thank you all !!!
PostPosted: Sat May 30, 2020 4:51 pm
I think the modern ignition systems have lessened the need for that shield. Not that I think they are a bad idea or anything. Because they aren't. I was just thinking about my truck. We drove back from a race in Bristol a couple of years ago in torrential rains for about 4-5 hours solid. Truck doesn't have a shield and never made a peep! I know I coudln't have done that with a points car! :D :D
PostPosted: Sat May 30, 2020 5:43 pm
Car Model: Slant Six M37
Anyone got a picture of one? I've never seen one and did not know such a thing exists. Both of my trucks are missing the shield as well, and I would like to make one.
 Post subject: D
PostPosted: Sat May 30, 2020 10:08 pm
d
PostPosted: Sun May 31, 2020 5:10 am
The first picture in this article:
http://www.slantsix.org/articles/Distri ... %20IIa.htm
Shows the shield on the left side of the picture in relation to the distributor, it is held by 2 bolts mounting the oil pump.
Thanks DI. I can create something like that.
PostPosted: Sun May 31, 2020 2:10 pm
I have a few spare shields that could be mailed-out, if needed.
Send me a PM if interested.
