It is currently Mon Mar 10, 2025 7:35 am
 Post subject: Van 904's question
PostPosted: Fri Apr 09, 2004 6:39 pm
I heard that Vans have lower first and second gear ratios then car 904's is that true and what are the actual ratios for both?
I was also told the final(3rd) ratio for both is 1.00-1
PostPosted: Sat Apr 10, 2004 10:00 am
Yes, the "Wide Ratio" 904 was offered in the later years in a number of different applications, I find most of them in 1981 and later SL6 vehicles.
The wide gear ratios are: 2.74 first, 1.54 second and 1 to 1 final (2.21 reverse)
The standard ratios ar 2.45 first, 1.45 second and 1 to 1 final (2.20 reverse)
PostPosted: Sat Apr 10, 2004 4:57 pm
So if I put a van 904(its the same as a car 904 isn't it?) it would be like changing to a 2.94 from a 2.76 in first gear right?
Is a van 904 the same in length width and depth?
Would it be a direct replacement to a car 904?
PostPosted: Sun Apr 11, 2004 11:41 am
Its not just vans that have the lower gears. Most 904s after about 1984 or so did. Often rebuilders swap in the lower set when rebuilding an older trans. Ever hear of a 998 or a 999 trans?? They are basically a 904, bolts in directly in place of an older 904, but these were the ones with the wider gearset. My 89 Dip with a 318 has it too.
PostPosted: Thu Apr 15, 2004 6:47 pm
I justy talked to the guy at the yard tonight and he is willing to trade my wifes olds w/ wiped engine bearings and my shell of a 74 Valiant for the /6 van 904 if he has one. he did 2 weeks ago! wish me luck!
PostPosted: Thu Jun 24, 2004 10:46 am
I went and pulled the van trans today now I just have to find time to swap it in, and replace the filter and fluid before the Pittsburgh race.
