It is currently Fri Oct 16, 2026 12:01 am
Post new topic  Reply to topic  [ 44 posts ]  Go to page 1 2 3 Next
PostPosted: Fri Jul 24, 2020 4:17 pm
Link / info to buy an adapter plate to Modify the SL 6 Overdrive Bell Housing to allow an easier install of a T5 transmission in your slant 6 vehicle.
What are you buying?[/size]
-1 plate that adapts the slant 6 OD bell to a Ford T5 trans.
-1 Set of 4 countersink bolts for mounting the Adapter Plate to your OD Bellhousing.
- Plates will be made from 6061 Aluminum.
- Optional add ons include crank pocket adapters for Small and Large pocket cranks.
Plates will be available for purchase from Gill Welding. Click Link Directly below.
https://www.gillwelding.com/product-pag ... -slant-six
Thank you!
Some Documentation: - Gill Welding Piece on the Left.
Gill Welding Part on the Left.
Weighs ~14# with Bell Housing.
PostPosted: Sat Jul 25, 2020 7:18 am
Excellent news! Thank you for all of your work on this Greg. 8)
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
PostPosted: Sat Jul 25, 2020 7:49 am
No problem Dave.
Also give some shout outs to Gill Welding for partnering on this effort as well.
PostPosted: Sun Jul 26, 2020 7:12 pm
Car Model: 1976 Dodge Dart Lite
Very much appreciated!
PostPosted: Sun Jul 26, 2020 7:27 pm
10-4 Good Buddy!
PostPosted: Tue Jul 28, 2020 7:28 am
I'm definitely interested, but confused on the price(s). :?:
PostPosted: Tue Jul 28, 2020 4:11 pm
I edited the first message in the post. Link to The For Sale Site is now posted.... Thanks Bryce and Team at Gill Welding!
I will be sending the Group Buy codes to the Folks committed in the list I have compiled in the First post of this message.
The Group Buy Rate 15% Discount Will be in effect until 8/28/20! So get your orders in soon! After that time you will have to pay $250 Plus Shipping.
PostPosted: Wed Jul 29, 2020 6:12 am
Not that this impacts my decision to buy one (I am), but can you confirm which T5 this kit is being designed around?
  • 83-93 V8 = 7.18" Input shaft length with .668" pilot bearing tip
  • 4 cyl = 7.41" input shaft and .590" pilot bearing
  • 94-05 V6 = 7.85" long input shaft and .668" pilot bearing
I already have a 90 V8 T5 with the 7.18" input shaft length. In my hunt last year (and associated posts) we all agreed the later V6 would have been a better option, as the guts are the same it just has a longer input shaft though it was harder to find and then more expensive. Fortunately, this longer input shaft is swappable into the V8 trans if it is the selected platform to build this kit around.
PostPosted: Wed Jul 29, 2020 8:05 am
I'm in on one of these too, although I have no idea what I'm doing! :lol:
I'm glad educated people are here to ask intelligent questions. I would not have known enough to ask. And with these details, and the ones Greg already provided, this adapter will become a useful pieve, rather than a frustrating piece of wall art.
DynoDave
WPC # 12304
PostPosted: Wed Jul 29, 2020 8:10 am
Codes have been sent to the Group for the group buy Rate.
Thank you!
PostPosted: Thu Jul 30, 2020 5:50 am
You should remember to bookmark this thread which has most of the details you need.
PostPosted: Thu Jul 30, 2020 6:20 am
Hey that link looks familiar.....
PostPosted: Thu Jul 30, 2020 12:27 pm
It should! It's a great resource you've pulled together. And from it, I believe the kit you worked with Gill on is going to use the 80s V8 input shaft length (the 7.18" one?)?
PostPosted: Thu Jul 30, 2020 7:42 pm
Yes The V8 Transmission should work best.. I have a V6 one in my swap and as you can see I had to do some machining on the input bearing adapter and the Input bearing / TOB support to make the V-6 Trans work correctly. The V-8 One ***should***be a bit more straightforward.
PostPosted: Thu Jul 30, 2020 7:43 pm
Folks on the Group Buy; Check your PM's for the Discount Code.... Still about 16 of you haven't opened your PM Mail.
