It is currently Sun Nov 08, 2026 1:55 pm
 Post subject: overheating
PostPosted: Sat May 02, 2020 4:12 pm
Car Model: 65 dart hopefully
Hello Everyone
I just fixed some timing issues only to have my D100 with a 225 slant 6 overheat about 1 mile from home
I replaced the thermostat water pump and radiator cap
ran it in my drive for 1 hour with radiator off
Ran well no steam or overheating
My question is I was looking for flow of coolant in radiator when thermostat opens I shot a video but its too big to send.
Not sure if coolant is flowing, is it a high flow?
Does anyone have a video of what it should look like?
Thanks
 Post subject: Re: overheating
PostPosted: Sun May 03, 2020 10:10 am
Hello Everyone
How is that possible when you have the radiator off? After a hour your motor should be a melted, warped mess. New parts won't do diddlysquat if your radiator is a plugged up mess! So what's the problem again, you lost me????????????????????????
PostPosted: Sun May 03, 2020 1:37 pm
My mistake I had the radiator cap off
Radiator was installed
PostPosted: Sun May 03, 2020 9:11 pm
Need the cap on for correct pressure and often to have correct circulation.. If you have a laser thermometer you can track the temps of the rad from top to bottom and check circulation. They are not expensive and are really useful.
https://www.aa1car.com/library/tstemp.htm
https://www.youtube.com/watch?v=KoT-PWg8Ahs
PostPosted: Tue May 05, 2020 2:46 pm
Hello Everyone
Well I took the truck on a 20 mile drive and made it home without any overheating
I had some seepage from lower hose but found the clamp was loose.
thanks for all the advice
onto belts and suspension
PostPosted: Mon Jul 27, 2020 5:26 pm
Hello Everyone
Well after working on the floor boards I took my truck (1971 Dodge D100 with 225 slant) out for a ride
The filler neck on the radiator cracked and the truck overheated....
After driving and waiting 20 minutes between stops I finally got her home (4 miles)
Well I found a 1974 Valiant radiator used near me and bought it.
Installed the used one are ran it around the block....
A little steam came out through the filler neck port and was deposited on the driveway
Went for a longer ride and lots of smoke came out same place
now engine is running poorly and I fear I have damaged it.
Top hose going into radiator was hot bottom hose from water-pump was cold
New water pump thermostat and hoses
I'm stumped any help please?
I fear I now have a bad radiator as well as head gasket?
Runs poorly and knock after I shut off key.
thanks
PostPosted: Tue Jul 28, 2020 4:16 am
Car Model: Slant Six M37
No flow through your "new" radiator. Lower radiator hose should at least get warm if it is allowing coolant to flow.
Regarding engine noises-knocks and what not. If starting the engine when it is cold after sitting overnight, does it still make noises?
PostPosted: Tue Jul 28, 2020 6:04 pm
I will start her up tomorrow and report back thanks
PostPosted: Sat Aug 01, 2020 5:32 pm
Hello
Good news
She started up without any issues
I ran her in the drive for an hour with a funnel full of coolant and saw many tiny bubbles escaping.
When the lower hose was as warm as the upper I shut her down
Took her for a 17 mile run and she did well
no hissing sputtering or detonation
Thank you everyone
