It is currently Sun May 10, 2026 9:56 pm
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 19 10 11 12 1381 Next
PostPosted: Fri Aug 14, 2020 6:57 am
Awesomeness!!
PostPosted: Fri Aug 14, 2020 7:45 am
I figured the tach drive dissy would be the discussion.
What do I know.
So the pan will not be of much use to you K frame, tie rod, pitman arm folks.
But with my open frame I hope it will work for the external pump engine plan.
I estimated 10 quarts, maybe 8.
One of our members from down under had posted one last year, so I started digging around.
This is a marine pan, unknown year or configuration.
A couple of internal baffles cast on the floor, and HEAVY.
PostPosted: Fri Aug 14, 2020 9:06 am
cast aluminum oil pan
Berry Berry interesting :D :D
PostPosted: Fri Aug 14, 2020 10:56 am
That pan will look so good polished and it will weigh less after it gets that mirror finish. Another benefit would be less wind drag. Such a good looking car!
Keep up the good work!
Mark
PostPosted: Fri Aug 14, 2020 11:47 am
polish the block, pan and Intake. and all the other AL Bits.
PostPosted: Fri Aug 14, 2020 1:07 pm
OK, now that we have seen the oil pan.....
Where on earth did you ever find a TACH DRIVE Slant 6 distributor????
PostPosted: Fri Aug 14, 2020 2:26 pm
Pan has some serious pitting issues, might not polish up so great.
Dist is second one I have ever seen.
Mark Goodman gave me a great idea.
Run the dist with a mechanical tach.
Run the engine with crank trigger.
Best of both worlds, old school and new school!
PostPosted: Fri Aug 14, 2020 2:45 pm
Its like only 3 or 4 people have access to the groovy old speed parts and Stan is one of them.
PostPosted: Fri Aug 14, 2020 3:31 pm
I have enough trouble with new parts. :roll:
PostPosted: Fri Aug 14, 2020 5:29 pm
I have seen the distributors, but never the pan?? Guess it is time to start scouring the shipyards!!
PostPosted: Fri Aug 14, 2020 7:34 pm
Very cool stuff!!
I read Mark's and Greg's posts to read, "Them 'luminum parts sher would look good all shiny. We volunteer ta do it fer ya!" :mrgreen: :lol:
PostPosted: Sat Aug 15, 2020 8:21 am
It's going to be a race car, it should look good, but not polished.
Too much work to polish it right now, maybe when I get old.
And Greg, I have seen some cool stuff in your circle also ;)
Life long collector of odd parts, with a slant attitude.
PostPosted: Sat Aug 15, 2020 8:26 am
Paint the pan with wrinkle black paint (or some other color) and you won't be able to tell it's pitted.
Jus sayin....
PostPosted: Sat Aug 15, 2020 10:09 am
Yes but his car is nice.. not a ruster :shock: :wink:
PostPosted: Sat Aug 22, 2020 6:05 pm
Finished the transmission mount. Here is it clamped up before welding.
The second picture is one side of the mid plate tabs, also the notched mid plate tube.
The engine goes all the way to the firewall and between this tube notch.
I should finish all the other side tomorrow.
I am then going to start putting the car together to go over to the Dallas Mopar Show.
Just want to get it out of the garage and into the daylight.
I just hope it doesn't rain like last year!
